Help...engine numbers ? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-09-2011, 08:01 PM Thread Starter
First im new to this sight and want to say thanks for your time and help,
my question is i just got a 65 lemans 2 door hardtop with a factory 4 spd,
i cant find out what motor is in it, the numbers on the front of the block are
490845 YN
i have looked everywhere and cant find these, i double checked the numbers and that is them,
anyone know ? thanks for your time
55gasser is offline
post #2 of 4 (permalink) Old 11-09-2011, 08:12 PM
68greengoat's Avatar
Welcome to the forum......
Well, it will be one of these. Check the block casting number located by the #8 cylinder next to the firewall. Also, check the date code by the distributor. Because '65/'66 had the same casting # as well as '68/'69. The date code will look something like d105.
YN A-body 69 350 265 Powerglide L-30 1x2 9790079 2 AC int seat 30
YN A-body 71 350 250 Powerglide L-30 1x2 481990 2
YN A-body 74 350 170 Turbo 350 L-30 N 1x2 488986 2
YN A-body 65 326 250 Powerglide L-30 1x2 9778840 2
YN A-body 66 326 250 Powerglide L-30 1x2 9778840 2
YN A-body 67 326 250 Powerglide L-30 1x2 9786339 2
YN A-body 68 350 265 Powerglide L-30 1x2 9790079 2
YN B-body 73 400 230 Turbo 400 L-78 T 1x4 481988 2
YN B-body 71 350 250 Powerglide L-30 1x2 481990 2
YN F-body 71 350 250 Powerglide L-30 1x2 481990 2
YN F-body 74 350 170 Turbo 350 L-30 N 1x2 488986 2
YN F-body 75 350 175 Manual L-76 E 1x4 488986 2
YN F-body 80 301 140 Turbo 350 L-37 W 1x4 525934 2
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 4 (permalink) Old 11-09-2011, 08:23 PM Thread Starter
thank you,
I did find the YN but nothing matches the 490845 i cant find those anywhere ?
55gasser is offline
post #4 of 4 (permalink) Old 11-09-2011, 08:30 PM
That's the engine unit number which would be on the PHS doc. That helps to verify it's the correct engine that came with that car IF it's on your PHS. You need to check the other numbers I mentioned to determine what the engine actually is, unless you have the PHS and the engine unit # does match the doc, then your doc will tell you all the info for the engine...
SOLD.....
462ci, 4spd
are these low numbers? 04black Engine Discussions 9 08-26-2011 12:12 PM
dyno numbers bayhammer Engine Discussions 16 05-18-2011 08:16 AM
Where to find engine numbers? Artemis Entreri 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 04-30-2010 06:21 PM
Engine Swap advice All numbers matching car Dirty Deeds 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 11 02-04-2010 12:07 PM
