How to tell a 72 GTO clone by VIN #??? - Pontiac GTO Forum
post #1 of 12 (permalink) Old 02-23-2010, 07:00 PM Thread Starter
I'm thinking about buying a 72 "GTO"... The guy says it had an engine swap & hes not sure if its a original GTO option Lamans. The decoder sites didn't help much. How can I tell if its a true GTO option? Thanks for the insight.
jnf84 is offline
post #2 of 12 (permalink) Old 02-23-2010, 07:36 PM
The best and most accurate way to verify a 72 is with the documentation package from PHS Automotive Services, Inc. If you select the fax back service they can have the build sheet and billing history to you within a couple of days.
05GTO is offline
post #3 of 12 (permalink) Old 02-23-2010, 08:58 PM
67 Basket Case Restorer
Too Many Projects's Avatar
The fifth digit in the VIN is an engine code. GTO's only came with a 400 or 455. The code for 400 is T, 455 is Y and 455 HO is X. If the fifth digit is anything other than these 3, it's not a GTO.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #4 of 12 (permalink) Old 02-23-2010, 09:16 PM
FNG69's Avatar
Got to get the PHS as the GTO was just a option on the LeMans coupe or Hardtop. Total production for 1972 GTO's was just 5,807. Hope you find out it's a MT w455 H.O. only 3 were make as a coupe and only 310 as a hardtop. I always like to call the coupe a post.I think it is better terminology. GOOD LUCK LES
FNG69 is offline
post #5 of 12 (permalink) Old 02-23-2010, 09:29 PM
68greengoat's Avatar
Here's a list of all the vin codes for a '72.... Just additional info....
1st digit - Division -
2 = Pontiac
2nd digit - Series:
D = LeMans
G = Luxury LeMans
3rd and 4th digits - Body Style:
27 = 2-door sedan (post)
36 = 4-door wagon, 2 seat
37 = 2-door coupe
39 = 4-door coupe
46 = 4-door wagon, 3 seat
67 = 2-door convertible
69 = 4-door sedan
5th digit - Engine Code:
D = 250 1-bbl L6 110 hp
M = 350 2-bbl V8 160 hp
N = 350 2-bbl V8 160 hp (dual exh.)
R = 400 2-bbl V8 180 hp
S = 400 4-bbl V8 200 hp (single exh.)
T = 400 4-bbl V8 250 hp (dual exh.)
Y = 455 4-bbl V8 250 hp (dual exh.)
X = 455 4-bbl V8 300 hp (455 HO)
6th digit - Model Year:
2 = 1972
7th digit - Assembly plant -
A = Atlanta, GA
C = Southgate, CA
D = Doraville, GA
G = Framingham, MA
L = Van Nuys, CA
N = Norwood, OH
P = Pontiac, MI
R = Arlington , TX
W = Willow Run, MI
X = Kansas City, KS
Z = Fremont, CA
2 = St. Therese, Quebec, Canada
Last 6 digits - Production sequence starting at 100001 at all plants.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #6 of 12 (permalink) Old 02-24-2010, 12:54 PM Thread Starter
thanks guys
Ok cool, thanks for all the info. I hope its a true GTO. If not you guys think I should still get it? Basic stats are: It needs all the typical restoration... from brakes, to the motor, to interior work, & body, but its not a complete "rust bucket". It seems like a good deal at $3k.
jnf84 is offline
post #7 of 12 (permalink) Old 02-24-2010, 04:31 PM
Call PHS and ask for the docs to be faxed. 3k is only a good deal if you can do the majority of the work and you have less in it when done than it's value. A true GTO will have a considerably higher value. A clone will turn you upside down in a hurry.
Check the frame for rust damage too. If the body is rough the frame may not be much better.
Mitch
1962 Impala SS
1938 Chev coupe
post #8 of 12 (permalink) Old 02-24-2010, 05:08 PM
Thumpin455's Avatar
Where is it? I'll come git it, nothing is too rough for me. There were quite a few T41 optioned cars in 72 and a T, Y, or X doesnt mean it is a GTO, but it would still be a cool car. You want to build it and enjoy it or flip it for profit?
Thumpin455 is offline
post #9 of 12 (permalink) Old 02-25-2010, 02:45 PM Thread Starter
Thanks again guys. Thumpin455 I just got a 68 Firebird that I'm fixing up for my self so I was thinking of maybe getting the "GTO" to clean up, get running, & flip.
jnf84 is offline
post #10 of 12 (permalink) Old 02-25-2010, 08:01 PM
Thumpin455's Avatar
I have been looking for one for a while now, but it would be July before I had funds available for another one at $3k.
IS VIN # 242176120037 Authentic For '66 GTO take5 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 11-02-2009 09:49 PM
question about a vin number on a 69 gto projectszero 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 15 10-13-2008 09:19 PM
Looking for '71 GTO (VIN 242371G116945) lostcarregistry 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 0 12-11-2007 04:28 PM
GTO- VIN Data Question brunk 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 04-03-2007 08:37 PM
Need help w/Vin # for 67 GTO jim's68 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 05-04-2006 06:46 PM
