Matching numbers ??/ - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-10-2011, 12:29 AM Thread Starter
Can anyone help me on the issue of the vin # matching the numbers on the block? Do they always have to match? I GTO car and the engine is a GTO but the Vin # is different from what is on the block above where is inprints the engine type. Mine is a WS. Thanks
tigers87 is offline
post #2 of 3 (permalink) Old 04-10-2011, 02:41 AM
likethat's Avatar
Look next to the timing cover on the same side as the WS. There will be numbers there and that should have the partial VIN at the end of the series.
67 GTO H.O. Convert 4spd
likethat is offline
post #3 of 3 (permalink) Old 04-10-2011, 10:15 AM
68greengoat's Avatar
To answer your question, yes, the vin on the block and body must match. But, that's just the beginning when figuring out if everything matchs the way it did when it came off the assembly line. Here's a quick 101 on matching:
Classic Car Part Number Matching Basics by Auto Media
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
Need help Matching Numbers Comicazy 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 4 06-09-2016 01:18 PM
Numbers Matching - What it means to you... 64ragtop 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 20 05-02-2010 12:14 AM
Not Numbers Matching texaz 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 17 06-03-2009 06:05 PM
Confused on numbers matching with a 65 jsmaem1106 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 7 03-09-2009 12:16 PM
matching numbers bamm 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 10 01-16-2009 11:39 AM
