Matching Numbers Car help! - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-15-2010, 08:27 PM Thread Starter
OrbitOrange's Avatar
This 70 GTO I just got is suppose to be a matching numbers car. I have a few questions.
How to I identify the block cubic inches and block number?
How to identify the cylinder heads?
How do I verify these all match the vin on the car?
I know the vin is located on the frame, the vin plate, door jam sticker, and partially in the body tag. Is there anywhere else the vin is identified?
Is 242 GTO?
How do I find out it possibly it might have been a judge?
Thanks guys, I know I ask alot of questions.
OrbitOrange is offline
post #2 of 3 (permalink) Old 11-15-2010, 09:15 PM
68greengoat's Avatar
Here's a good resource for all your questions:
Pontiac Engine Codes
Yes, 242 is a GTO. If the vin starts with anything else, it is not a GTO.
The Judge option is code 332 on the PHS
Don't forget to order up the PHS doc...
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 3 (permalink) Old 11-16-2010, 07:09 AM
To see if the engine is original it will have the last 5 numbers of your VIN code stamped on the block.
They are on the passengers side of the block up by the water pump it make take a lot of cleaning to see them.... they run vertically
The date code of the block will be up on the block by the distributor hole.... usually the engine is created a couple or three weeks before the car is born
Check the online resources for where engine size codes are... 68Green's Year1 is a real good link go there 4 sure
can also try here
http://www.teufert.net/ teufert has a lot of links to stuffs
http://www.teufert.net/identify/identify.htm
To find Judge possibles for a 70.. Only way for sure is PHS .. Some tips on 70 are the grills on a 70 Judge are all black instead of the GTO's argent silver around the bezel(this can be done by cloner though)
The rear spoiler should look factory installed not homemade drilled.. Always on the dash the Judge emblem should be there and should have ram air3 cable dash area ram air hood
Eric65 is offline
Need help Matching Numbers Comicazy 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 4 06-09-2016 01:18 PM
Engine Swap advice All numbers matching car Dirty Deeds 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 11 02-04-2010 12:07 PM
How rare is a numbers matching car? F-RICE 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 17 07-26-2009 07:27 AM
matching numbers bamm 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 10 01-16-2009 11:39 AM
