Need help with 65 GTO cowl tag accessories - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-29-2016, 07:37 PM Thread Starter
Hello all, I am about to purchase another 65 GTO but wanted some help with the cowl tag. I think I can assume this car is a true GTO as it is a Kansas built car with the 5N. It also has power steering, brakes, console, rear defrost, cold factory AC, tinted glass and power windows. Can anyone tell if all that is correct on the tag and if it is showing more than that? Thank you guys so much!
Windham14 is offline
post #2 of 2 (permalink) Old 03-29-2016, 10:46 PM Thread Starter
I've actually found most of the info but a few options on the tag I cannot so maybe you guys can help. The P in the first set and the P in the 3rd set. I assume power steering and power brakes as the car does have those options. Looks like this car has tons of options.
Need help with 64 gto cowl tag decode??? ezskater 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 12-02-2015 04:13 PM
1965 GTO Cowl Tag sdseay 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 12-15-2014 06:06 PM
1965 Gto Cowl Tag Codes ???? D1147 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 11-13-2014 07:32 PM
1965 GTO Cowl Tag question riggsjr 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 07-15-2014 07:54 AM
1971 GTO cowl tag question????? samanatoo 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 10-01-2008 09:01 AM
