need to verify how to determine if numbers matching - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-01-2013, 08:24 AM Thread Starter
My friend just brought a 66 gto and I am not sure on the numbers can you help.
Body Tag
03A 0614
ST 66-24267 KAN 731 BODY
219-B D-1 PAINT
W 2KW
VIN# 242676K124394
MANIFOLD
8782898
EXHAUST
8779308
BLOCK CASTING
B248
9778789
D
DIFFERENTIAL
9783393
CAN YOU PLEASE HELP WITH THIS.
hangerhi is offline
post #2 of 3 (permalink) Old 08-01-2013, 07:24 PM
68GTO4004Spd's Avatar
This website will help you decode. Get the PHS (Pontiac Historical Society) will give you all the details and verify originality. 66 didn't have the VIN on the block, you will need to find the EUN on the PHS docs to verify.
68GTO4004Spd is offline
post #3 of 3 (permalink) Old 08-01-2013, 10:11 PM
68greengoat's Avatar
BLOCK CASTING
B248
9778789
D
Date code B248 didn't have 9778789 block. That was for a '65/'66/'67. I bet if you look at the code again, the last digit is a 6 for '66, and not an 8 for '68. There should also be an 2 letter engine code under the engine unit number on the front passenger side of the block. Maybe the D is part of it? There also should be a date code on the rear end by the pumpkin. Will resemble the date code on the block...
As 68GTO said, get the PHS too....
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
Need help Matching Numbers Comicazy 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 4 06-09-2016 01:18 PM
Numbers Matching????????? Pete F 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 8 03-04-2012 10:32 AM
Matching numbers ??/ tigers87 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 2 04-10-2011 10:15 AM
Not Numbers Matching texaz 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 17 06-03-2009 06:05 PM
matching numbers bamm 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 10 01-16-2009 11:39 AM
