numbers on chassis? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 09-21-2012, 10:45 PM Thread Starter
numbers on chassis?
Hi guy's newbie here, i just got into restoring a 69 GTO Judge and once the chassis was pulled from under the car I found a set of numbers on the left rear wheel side of the chassis and was wondering if anyone can help and let me know if these should match the vin tag. thanks for your time..
monster is offline
post #2 of 5 (permalink) Old 09-22-2012, 10:49 PM
The serial number (last 6 digits) on the frame should match the vin number's last 6 digits.
05GTO is offline
post #3 of 5 (permalink) Old 09-23-2012, 06:53 AM
: Driver's side top rear should have a sequence that is also present in the VIN.
post #4 of 5 (permalink) Old 09-23-2012, 11:38 AM Thread Starter
Thanks to both for your prompt response i apreciate it, but as I said my numbers are on the rear left side and on the side of the chassis not on top. again thanks for your time..
monster is offline
post #5 of 5 (permalink) Old 01-01-2013, 06:15 PM
Same Issue Here
Hi,
I am also looking to decode some numbers. i found two sets of numbers on my frame behind drivers side as well. One number is a part number and i think the other should be a date code but i cant for the life of me figure out the code. I have a 65 GTO and the Frame Part number is 9780911 which makes sense but the date code, well i think it is a date code is 012144N2. Have you found any answers?
Phil
psullivan is offline
Body off chassis Eric Animal 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 12-04-2010 08:47 AM
Chassis in my garage! Eric Animal 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 23 11-30-2010 10:44 PM
67 GTO chassis Eric Animal 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 11 11-13-2010 10:47 PM
My new chassis for the 67 GTO Eric Animal 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 17 03-10-2010 06:50 AM
Chassis number 1969GTOConv 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-06-2009 05:47 PM
