Original owner numbers matching 67 GTO - Pontiac GTO Forum
post #1 of 16 (permalink) Old 05-13-2014, 05:56 PM Thread Starter
Hello, I'm a new member to the site and wanted to introduce myself. I'm here because my grandfather is an original owner to a numbers matching 67 gto 400BB 4-speed that has been sitting in his garage for 30+ years. He is handing it down to my dad who is looking to restore it, probably just get it running first though. My question is what steps should be taken to get it running? What should be replaced on a car that has been sitting for 30 years? Any help would be appreciated, as we're looking to pull it out of the garage this summer and get it back on the road. Attached are images as it sits now... and for the past 30 years...
ID:	39210   Click image for larger version
kuchinski67 is offline
post #2 of 16 (permalink) Old 05-14-2014, 01:10 AM
Roger that's Avatar
step 1: get rid of all those boxes!
new spark plugs, fuel filter, fresh gas in the tank, new air filter, new battery, change oil, oil filter. I would see if the engine turns over by hand, prime the carb and see if she will start and run.
Roger that is offline
post #3 of 16 (permalink) Old 05-14-2014, 05:14 AM
As above but pull all the plugs and squirt a little trans fluid in the cylinders before you try to turn the engine over by hand. Don't rush this.
I would also recommend pulling the gas tank and have it boiled out before just throwing gas in there. If there is rust and dirt in the tank and it gets sucked up and run through the fuel system debris could get up to the carb which is no good.
Hook a battery up and check all electrical systems for function. There could be rodent damage to the wiring so you'll be checking for shorts.....have a fire extinguisher on hand.
What a great family heirloom! Good luck!
post #4 of 16 (permalink) Old 05-14-2014, 07:48 AM
SANDU002's Avatar
"Alky" hit the nail on the head ....DON'T RUSH THIS. By taking your time you will avoid additional problems created by being in a hurry to get it running. Also add new belts to the list of parts.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #5 of 16 (permalink) Old 05-14-2014, 09:24 AM
Quoted: 98 Post(s)
What these guys said. No rushing! I see you're in CA....whereabouts? Good luck with the trunk, roof, and hood. I hope they're not caved in from being used as a shelving system! And thank goodness this car is going to see the light of day again. Many do not.
post #6 of 16 (permalink) Old 05-14-2014, 10:11 AM Thread Starter
Thanks for all the feedback guys! I will definitely look into getting the tank boiled before putting fresh gas in and firing it up.
I will keep the progress posted. Looking to dig the car out in the next couple months.
If there are any links or restoration builds that you recommend please post. This is mine and my fathers first resto and could use all the help.
Im out of Newport Beach but the car lives in Covina.
post #7 of 16 (permalink) Old 05-14-2014, 10:20 AM Thread Starter
What's a good parts store to buy OEM parts... hoses, belts, fuel system, etc.?
post #8 of 16 (permalink) Old 05-14-2014, 10:45 AM
Quoted: 98 Post(s)
AMES performance is a favorite of mine. OPG is in your backyard, but is the most expensive and usually not as high quality.
post #9 of 16 (permalink) Old 05-14-2014, 11:30 AM
68GTO4004Spd's Avatar
In addition to everything above, replace everything that is made of rubber that has fluids or vacuum. There are rubber hoses at each end of the fuel lines, may wan't to change the sock on the gas tank sending unit while you have the tank out. Before you hit the road, go through the brake system, and replace the fluid (brake fluid adsorbs water). Check the metal brake and full lines for leaks. Agree that Ames is good, as well as Performance years, stay away from Year One, way expensive. FWI, Pontiac engines are not refered to as big block or small block (also the distributer runs CCW).
68GTO4004Spd is offline
post #10 of 16 (permalink) Old 05-14-2014, 11:44 AM Thread Starter
Thanks for the heads up 68GTO! All good info... I'm new to the pontiac world and didn't know about the bb/sb. Also, what is CCW?
Personally Im a chevy guy and the attached image is my baby that I've been working on the past year. Looking to turn it into a track monster so I can rip on these modern super cars.
Original owner numbers matching 67 GTO kuchinski67 Member Introductions 6 05-13-2014 09:25 PM
First project 70 GTO, numbers matching topgun828 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 12-20-2012 11:50 AM
Matching Numbers 71 GTO? 1971greenGTO 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 02-12-2012 05:33 PM
Matching numbers on a 1969 GTO tigers87 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 04-10-2011 10:25 AM
