Protect-o-Plate - Pontiac GTO Forum
 1Likes
post #1 of 13 (permalink) Old 07-27-2010, 11:51 PM Thread Starter
LPTudor's Avatar
Protect-o-Plate
I've been researching protect-o-plates and it seems like there's conflicting and incomplete information out there regarding how to read it and what clues it can give regarding whether the car truly is numbers matching. Can you take a look at this pic and help me figure out what it says and where to look to see if the car matches up with the protect-o-plate? Based on another example of 68 protect-o-plate, I'm not sure it's an original one (the other example looked red and white plastic) and want to be sure it's not doctored up.
Here's the pic and thanks:
LPTudor is offline
post #2 of 13 (permalink) Old 07-28-2010, 09:07 AM
68greengoat's Avatar
I've never seen a protect-o-plate so I can't verify if it's original or not. As far as the numbers, this is what I do know.
2 - pontiac, 42 - GTO, 67 - convert., 8 - 1968, B -Baltimore(assembly plant), 117636 - production number. Of course, these numbers need to match the cars v.i.n., which I'm sure it does. For a numbers matching engine, 117636 needs to match the engines v.i.n number, last 6 digits, located on a machined pad on the passenger side by the timing cover. That number should look like 28B117636.
Somebody should be able to decode most of that plate. It just isn't me...
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 13 (permalink) Old 07-28-2010, 09:15 AM
Quoted: 98 Post(s)
That does not look like my '65 protect-o-plate, which has two metal index tags. Your one tage DOES have the engine code, YS , but should also have the engine number. My '65 tag has the engine number right after the engine code. Is there another plate on the other cover? The delivery date to the customer is on your card.
post #4 of 13 (permalink) Old 07-28-2010, 09:29 AM
Here's a link to a '68 non GTO plate from High Performance Pontiac....
Pontiac Ident O Plate Program Front View Photo 7
Completely different from a '65....
They list '63 - '72
SOLD.....
462ci, 4spd
post #5 of 13 (permalink) Old 07-28-2010, 10:16 AM Thread Starter
LPTudor's Avatar
The example at 68green links to below is the one that caused me to wonder if this plate is real. According to that example, the block code should be on it, but not the engine number.
I'm wondering if the protectoplates could look different depending on the dealership and how they set up their protectoplate making machine??? It would seem to me that the plates were made at the dealership, not the factory, because they've got the buyer's name on them. (And according to the link provided by 68, new protectoplates could be made up for the second owner.
This following excerpt from this link suggests that it was dealers who had to print them up -- so I suppose it could differ from dealership to dealership.
Hagerty Insurance Agency
"The National Corvette Restorers Society says Chevrolet began providing Protect-O-Plates to new owners in 1965. However, a Pontiac Dealer Service Bulletin issued in September 1966 notes that “owner plates” were provided for 1964 models. The same bulletin announced a change in the way plates were going to be furnished to owners. It stated that the factory would no longer issue them. Instead, dealers were to buy a Model M-14 Dymo (reverse print) Tapewriter embossing machine, so they could emboss blank plates at the dealership level."
LPTudor is offline
post #6 of 13 (permalink) Old 07-28-2010, 02:19 PM Thread Starter
LPTudor's Avatar
Here's a link to another 68 GTO protectoplate --- obviously looks different from the picture I posted obve, but the one I posted above has what looks like an official looking sleeve.
68 gto :: 100_0121.jpg picture by brunno2711 - Photobucket
LPTudor is offline
post #7 of 13 (permalink) Old 07-28-2010, 08:35 PM
crustysack's Avatar
here is my plate from a 65 tempest- this is as original as it gets this is the original Guardian Maintenance Service booklet with the steel protecto plate that is reverse embossed that the dealers would run on the receipt like the old school credit card copy machines
But why are you going by the plate to determine if the car is #'s matching?? Go PHS and eliminate all questions
ID:	8188   Click image for larger version
ID:	8189   Click image for larger version
ID:	8190   Click image for larger version
ID:	8191   Click image for larger version
bkbaird likes this.
crustysack is offline
post #8 of 13 (permalink) Old 07-29-2010, 12:51 AM Thread Starter
LPTudor's Avatar
Definitely PHS, but I was wondering if the plate included information that is not included on the PHS -- like the transmission code. If the engine and transmission code is on the PHS, then the PHS would both identify the numbers are matching and determine that the plate is original and not a fake.
LPTudor is offline
post #9 of 13 (permalink) Old 07-29-2010, 08:28 AM
The enginge unit#/vin#/engine code along with the trans unit#/trans code is in the PHS doc.
On the card you provided, the vin is 242678......, YS is the engine code, PX is the trans code.
Using the YS info, PHS said(providing the info on the card is correct), it's a 400, 4 barrel, 350hp, 10.75 comp, 2.93 axle(standard w/air, I believe you have air). There were special order axles too which PHS would hilite for you the axle that was ordered with your car.
SOLD.....
462ci, 4spd
post #10 of 13 (permalink) Old 07-29-2010, 09:03 AM
Quoted: 98 Post(s)
Thanks for posting this information, guys. I didn't know of the above listed links.
Pontiac Protect-O-Plate ? classic_car_fan 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 04-23-2009 07:40 AM
To plate or not to plate??? 64GOAT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-05-2008 09:24 PM
So what plate? ChiefyGTO Member Introductions 9 11-19-2006 11:33 AM
How to protect door sill "aluminum" RookWV Exterior Discussions 2 04-27-2005 06:30 AM
Protect your rights (Warranty) SStoGTO Service, Maintenance and Technical Discussion 6 04-15-2005 08:48 PM
