Rear Carrier Axle Stamping Numbers Help!!! - Pontiac GTO Forum
post #1 of 2 (permalink) Old 07-23-2009, 05:26 PM Thread Starter
Lukeduk1980's Avatar
Send a message via Yahoo to Lukeduk1980
OK, if you recall, I originally was getting some help with the rear axle numbers and it believe it cam from a 1969 Chevelle. I found some carrier stamping numbers that I need some help with. Here are the stamping numbers:
3969278 NF
Can anyone help me decode these stamping numbers? Also, I confirmed that the rear axle is a 12 bolt (Non-Posi) 4-link Axle. two at the top and 2 on the bottom The coil springs sit on the rear axle so I think that means its a coil over rear axle. I think this is the Safe-T Track setup.
Again, the stamping number on the AXLE says: KD 0 or a 6 3362
The Carrier stamping numbers are: 3969278 NF
Any information would be greatly appreciated.
Lucas
Lukeduk1980 is offline
post #2 of 2 (permalink) Old 07-23-2009, 09:05 PM
68greengoat's Avatar
Lucas
Safe -T-Track is just another way of saying "posi". Since you already confirmed that it's not a posi, then, it's not a safe-t-track.
68greengoat is offline
Need help with trans/diff fluid change kegbelly Service, Maintenance and Technical Discussion 29 02-10-2009 12:01 AM
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
Rear Axle Replacement DaveH 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 12-18-2007 08:20 AM
Rearend Marty 2004-2006 GTO General Discussion 107 10-17-2005 09:32 AM
