Rear Diff. Tag - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-08-2009, 10:01 PM Thread Starter
Rear Diff. Tag
On what bolt does the stamped metal tag that reads "Use Limited Slip Diff. Lube Only" get bolted to on the differential cover and how would it be oriented?
Three deuces and a four-speed...
Three Deuces is offline
post #2 of 3 (permalink) Old 10-09-2009, 07:54 AM
Not sure if it's correct but, I've always seen them on the right side of the cover looking from the rear at about 4:00 with the tag going up from the bolt hole.
post #3 of 3 (permalink) Old 10-09-2009, 10:48 AM
Quoted: 98 Post(s)
Bottom right bolt at about 4-o'clock. The tags on my '65 and '67 are horizontal and protrude past the cover plate. Don't know if that orientation is "correct" but that's how mine are...
Identifying the Rear Diff Jim 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 7 03-24-2009 05:39 PM
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
