Rear end numbers? - Pontiac GTO Forum
post #1 of 1 (permalink) Old 07-18-2010, 11:04 AM Thread Starter
Rear end numbers?
The 69 GTO I picked up has a rear end with the converging ribs. THe casting number is 9795084 with a /249\ below it. On the other side is a CFD. What does this tell me? I looked high and low, and found nothing specific. Previous owner told me it was posi. I can't find any other markings and I have yet to open it. It does have a tag that states to use a specific fluid only bolted to one of the cover bolts? Also, when I turn the passenger side wheel, the drivers does nothing. When I turn the drivers side, the passenger side follows in the same direction as the driver side. Not posi?
bobthewelder is offline
?- looking for new rear end gears and rear suspension whytedude422 Service, Maintenance and Technical Discussion 3 03-31-2010 03:11 AM
04 rear end 740tank 2004-2006 GTO General Discussion 9 03-13-2010 11:08 PM
Searching for original part numbers on motor tranny and rear par4n1 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 17 02-05-2010 11:11 AM
Different Rear End AGETECH 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 01-18-2010 06:22 PM
Rear Carrier Axle Stamping Numbers Help!!! Lukeduk1980 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 07-23-2009 09:05 PM
