stange engine vin - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-14-2009, 06:28 PM Thread Starter
stange engine vin
just bought 68 HO 4Sp Conv barn find with 33k engine is WS and was in pieces in trunk vin on motor has only 3 numbers from vin tag and the 22 is stamped at the end of the numbers , car is nov 67 and all dates on engine are time correct all charts say vin should be 6 numbers from vin and 22 at beginning anyone else seen this before. thanks
crzydiver is offline
post #2 of 4 (permalink) Old 05-14-2009, 08:54 PM
BobG's Avatar
I don't know for sure, but I would be suspicious. It sounds like someone is trying to pass the car off as a numbers matching GTO, and all they have for the motor is a collection year correct parts with no way to authenticate ... I'd be very wary of this, unless they're selling it for a non-numbers matching price of a goat in that condition
BobG is offline
post #3 of 4 (permalink) Old 05-14-2009, 09:48 PM
68greengoat's Avatar
Here's the location of the VIN code on the motor. It should read something like 28P123456. 2 = pontiac, 8 = 1968, P = final assembly plant and the last 6 digits should match the last 6 digits on your VIN plate which is located on the drivers side at the base of the windshield on the dash. You need to look from the outside of the windshield to see the plate. If it's a numbers matching motor the VIN plate will read 242678P123456. 2= pontiac, 42 = GTO, 67 = conv., 8 = 1968, P = final assemly plant and the last 6 digits is the sequence number that should match the block for a numbers matching motor.
68greengoat is offline
post #4 of 4 (permalink) Old 06-17-2009, 02:49 AM
not saying your car is none numbers matching but with the block restamping kits thay got out and the corect rivets to reattach the vin tag and body tag after removeal off the body for restoration ae being made it is all to easy to find a junk car take the takes off and buy a block restamping kit and use a full size car block. sad but true
danthepontiacman is offline
How To Read A Vin GTO JUDGE Service, Maintenance and Technical Discussion 0 08-05-2007 09:33 AM
cam Q's GTO6 2004-2006 GTO General Discussion 1 10-18-2006 07:34 PM
LS-2 Engine Break-In danrieke Engine Discussions 16 12-27-2005 01:43 PM
My Dealership Experience Today in_burrito 2004-2006 GTO General Discussion 43 12-20-2005 05:14 PM
Worlds Fastest Production Car 05GTO The Lounge 15 11-07-2005 07:45 AM
