top cowl plate where the V.I.N tag attaches - Pontiac GTO Forum
post #1 of 10 (permalink) Old 11-15-2009, 11:32 AM Thread Starter
I need to replace the top plate on the cowl where the dash pad sits, the panel that has the V.I.N tag attached. It is for my 69 GTO, does anyone know who sells the panel, this one is beyond repair.
DrBoeing is offline
post #2 of 10 (permalink) Old 11-15-2009, 12:02 PM
crustysack's Avatar
crustysack is offline
post #3 of 10 (permalink) Old 11-16-2009, 09:02 AM Thread Starter
Thanks for the link, unfortunately, this is not the correct part, mine runs the length of the windshield but is about 6 inches wide. It goes from the windshield to the dash panel and is spot welded to the upper cowl.
DrBoeing is offline
post #4 of 10 (permalink) Old 11-16-2009, 08:25 PM
crustysack's Avatar
sent pm for possible source
post #5 of 10 (permalink) Old 11-17-2009, 05:10 AM Thread Starter
Thank you, I have read it and will be sending out an e-mail.
I will also post a photo of the part here.
DrBoeing is offline
post #6 of 10 (permalink) Old 11-17-2009, 07:14 PM Thread Starter
here is the panel that I am looking for.
ID:	5974   Click image for larger version
DrBoeing is offline
post #7 of 10 (permalink) Old 11-17-2009, 08:38 PM
crustysack's Avatar
that is definitely not reproduced- you will need a donor car
post #8 of 10 (permalink) Old 11-17-2009, 11:28 PM
646904GTO's Avatar
I suppose if your good enough(or know someone who is) you could repair that.
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #9 of 10 (permalink) Old 11-18-2009, 06:53 AM
68Resto-mod's Avatar
You can just replace the leading edge where it meets the windshield with Ames Performance part number G134L. Cutting and welging will be required. This assumes the rest of the part is no too badly rusted. The Ames part has to be cut down because it is made to fit El-Camino and Chevelle as well. I had to do this on my 68.
68Resto-mod is offline
post #10 of 10 (permalink) Old 11-18-2009, 08:24 AM Thread Starter
I have a die grinder and also access to a Tig welder, so I will check out AMES
DrBoeing is offline
Cowl Tag Petey D 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 03-11-2010 01:38 AM
His n hers shifter top plate jes 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-05-2009 02:25 PM
1971 GTO cowl tag question????? samanatoo 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 10-01-2008 09:01 AM
1966 cowl tag jeremy 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 04-11-2007 06:14 AM
