Trim tag help on a 68 convert - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-03-2015, 03:37 PM Thread Starter
Guys,
I have most of the tag figured out but I cant decipher a couple of pieces and was wondering if you could assist.
on the top of the trim tag above the factory built I have a 50 1SC
are these trim options?
68gtored is offline
post #2 of 2 (permalink) Old 06-03-2015, 09:10 PM
Roger that's Avatar
This is called your fixture or gate number. This is the location in the plant where your body was welded up. Gate 50. The dash 1 is the work shift, in your case 1st work shift. Some cowl tags do have a letter or two after the work shift but most do not. These letters are unkown at this time.
389, transistorized ignition, and a power pack of 3 deuce carbs..... and she chews up other cars and 426 Mopars.
Roger that is offline
Trim tag decode 1coolduck 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 0 08-25-2013 08:13 PM
Trim Tag Help Red1970GTO 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 10-06-2012 01:51 PM
Trim Tag Gold GTO 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 2 08-31-2010 07:55 PM
Trim tag code help Too Many Projects 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 7 12-01-2008 10:22 AM
64 trim tag Help rare4k 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 10-10-2006 08:21 AM
