Trim Tag Info - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-10-2015, 10:26 PM Thread Starter
Trim Tag Info
On this 66 GTO trim tag, (pic attached) what is the 8118 in the paint code? And also the GD B1337? Thanks
ID:	66098   Click image for larger version
ID:	66106   Click image for larger version
91Red&White is offline
post #2 of 6 (permalink) Old 10-11-2015, 06:01 AM
I believe the number after BAL is the production number, 8,118 produced at Baltimore plant.
The other letters and numbers should be the transmission number
The punched hole in the lower left means it has a shoulder harness, a factory installed provision.
shoeman68 is offline
post #3 of 6 (permalink) Old 10-11-2015, 06:17 PM Thread Starter
Thanks shoeman. So what is the body color? Is this a matching numbers car?
post #4 of 6 (permalink) Old 10-12-2015, 06:55 AM
Appears to be a matching numbers 389 for barrel. Black interior. The information I gave before on BAL 8118 has me stumped.
The Vin number shows that it is a V-8 car and the 39,561 produced in Baltimore
The engine code is YS designating a 389
post #5 of 6 (permalink) Old 10-12-2015, 07:51 AM
267 on the very top is the job number assigned for the day of production. this number will be noted on the original buildsheet.
BAL 8118 is the 8118th Pontiac A body 2door hardtop BODY built out of the Baltimore plant for the '66 model. Post Coupes and converts had their own numbers in this spot.
The letters GD B in the bottom line are internal and can't be explained. Baltimore plant had to do things in their own odd way
If this GTO had been built out of Pontiac, Kansas City, or Framingham plant, the body accessory codes would be in place, and would be easy to decode the factory installed options which required body modifications at fisher body plant.
post #6 of 6 (permalink) Old 10-12-2015, 06:22 PM
Quoted: 349 Post(s)
It is also possible that the car was ordered by a customer or dealer with a non-production color. The paint codes were left off on these cars. You can verify with the PHS documents for your car and verify the color. If it was a custom ordered color, the paint color will be listed/shown as "Special" as several members have run into this trying to verify their car's original non-production color. Unfortunately that does not help verify the color, but it does verify that your car's color was not a production color. I had a '67 GTO convert that had no paint code and was painted Iris Mist, a 1965 color that was not available in 1967.
Cowl Tag info my67goat 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 05-26-2014 10:43 PM
Trim tag decode 1coolduck 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 0 08-25-2013 08:13 PM
Trim Tag Help Red1970GTO 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 10-06-2012 01:51 PM
Trim Tag Gold GTO 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 2 08-31-2010 07:55 PM
64 trim tag Help rare4k 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 10-10-2006 08:21 AM
