VIN "engine used" - Pontiac GTO Forum
post #1 of 7 (permalink) Old 02-20-2012, 06:24 AM Thread Starter
VIN "engine used"
Can someone please tell me why my data plate has "KAN" on it but the car's VIN has a "P" for Plant?
Also, after the "P" for Plant, the VIN has 2 for "engine used." What does the no. 2 mean (other than u know what)?
The car is a '66 GTO Cv w/ac and a 2spd.
TIA for your help.
us66 is offline
post #2 of 7 (permalink) Old 02-20-2012, 06:57 AM
Quoted: 22 Post(s)
Kansas City built car with a Pontiac built engine
Instg8ter is offline
post #3 of 7 (permalink) Old 02-20-2012, 09:49 AM
68greengoat's Avatar
Is your vin by the windshield, which I believe you're referring to "car's vin", 242676P2xxxxx? That P is for Pontiac, MI.
The 2xxxxx is the production number, they started with 100001. When the plant exceeded 100,000 units, they started using 2xxxxx. That's for V-8s, 6 cyl started with 6xxxxx.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #4 of 7 (permalink) Old 02-23-2012, 05:27 PM Thread Starter
That clears up the disparity for me, thanks.
us66 is offline
post #5 of 7 (permalink) Old 02-23-2012, 06:03 PM
The data plate should list "Pon" to match the 7th digit of the vin number "P". If they don't match someone has changed one of the plates.
Can you post pictures, distinctive rivets were used to attach the plates.
The blocks had no Factory ID marks specifying where they were built.
05GTO is offline
post #6 of 7 (permalink) Old 02-23-2012, 06:10 PM Thread Starter
68GreenGoat, I just now went back and reviewed the title. It has 12 numbers and the letter P. There are 6 numbers before and after the P. The numbers after are: 271729. I wrote a note down from somewhere that defined the number after the P as the engine used in this car, and the last 5 digits as the "Unit Number."
Please note your last example has 6 "x"s after the 2, which I'm sure is a typo. I can accept your explanation alright, but in '66 only 12798 Cvs were built, so the count must include other goats, which should not because its VIN starts with 242676 ('66 GTO Cv). Could this qualify as another GTO "mystery" or is there a better explanation?
Thanks for your response.
us66 is offline
post #7 of 7 (permalink) Old 02-23-2012, 10:36 PM
Since the number after the P isn't a 6,7 or 8 all it means is that it's a V-8(1-5). But as mentioned before, in '66 they exceeded 100000 units and had to start with the number 2xxxxx(sorry, you're right my other post was a typo). But, that was for all V-8 Pontiacs produced in '66, not just GTOs and that number is plant specific. In your case P(the Pontiac, MI plant). I believe I read in '65 where sometime in February the Pontiac, MI plant exceeded 100,000 units.
Read what 05GTO had to say about the vin and data plates not matching. If one plate sez P(PON) and the other sez KAN, one of those plates has been changed. Post up pix of the plates, which was recommended, and it probably will be determined which plate was replaced......
SOLD.....
462ci, 4spd
Some "custom" engine parts. Eric Animal 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 18 09-22-2011 06:48 PM
1970 "Judge" engine block VIN location question AllRise70 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 01-26-2011 10:50 PM
Engine "non-start" dilemma The Patchwork Tiger 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 11-05-2010 09:19 PM
"Check Engine" after CAI install???? Shockrock3 Service, Maintenance and Technical Discussion 1 12-09-2006 05:45 PM
