Vin Number Locations? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-27-2011, 04:59 PM Thread Starter
I have a 1968 GTO and believe that my Muncie transmission is the original. I can see the casting number as well as the build date stamping on the passengers side. However, I do not see the vin number on either side. Is it possible it is on the top? If yes, what side would it be on and does anyone have a photo. The tranny numbers that I have are as follows:
Transmission Casting Number: 3925660 Side Cover 3884685 Transmission Casting Date: P8B12
Also, does anyone have a photo of a correct distributor for my 1968 GTO 4-speed and where the id number is on the distributor?
Thanks,
Al
dillon14 is offline
post #2 of 6 (permalink) Old 04-27-2011, 06:42 PM
Thanks,
Al
Hey Al, welcome to the forum!
The date code P8B12 is for Feb. 12 1968,
The casting number 3925660 was used from 68 to early 70,
The casting on the side cover 3884685 was only used in 68,
You should be able to find the serial number on the side of the case;
05GTO is offline
post #3 of 6 (permalink) Old 04-27-2011, 07:09 PM
likethat's Avatar
The Dizzy will be stamped on the big side of the body where the cap is attached to.
67 GTO H.O. Convert 4spd
likethat is offline
post #4 of 6 (permalink) Old 04-27-2011, 07:15 PM
likethat's Avatar
Not to step on 05's post here is a pic
likethat is offline
post #5 of 6 (permalink) Old 04-27-2011, 08:38 PM Thread Starter
Likethat,
dillon14 is offline
post #6 of 6 (permalink) Old 04-28-2011, 09:36 AM
67 Basket Case Restorer
Too Many Projects's Avatar
The 5660 main case was used for all 4 speeds from 68-70, not just the M22. The M22 would be distinguished by the large ( TH400) output yoke and a drain plug near the bottom of the case.
I've seen many VINs stamped on the top too.
In likethat's pic, the red box is the build date. If you look above that, you can see a VIN stamped in small letters
If the build date of your car is before Feb 12, there's no chance it's original. If after, then I would try to get a small mirror and look on top. Probably be very difficult to see/read if dirty.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
2011 Hot Rod Power Tour dates and locations jetstang The Lounge 1 10-23-2010 08:27 AM
what is this? number 3 Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-04-2010 05:27 AM
Decoding locations, engine, trans, heads rigosgto 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 09-10-2010 03:27 PM
Locations of horns on 1964 GTO bruce464GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-02-2009 03:54 PM
question about a vin number on a 69 gto projectszero 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 15 10-13-2008 09:19 PM
