Vin plate restoration - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-23-2009, 01:14 PM Thread Starter
Josh.AZ.GTO's Avatar
I have not gotten to this point yet but I have read a great deal about the legality issues of tampering with VIN removal and so on..... my question is not about that.
My question is about Vin Plate restoration. My GTO sat outside for years and the VIN number is weathered. Has anyone restored their vin plate. What are the best methods. Or is it just a lost cause. My entire firewall is surface rusted from years of sitting. Any ideas how to go about that?
Just thought here:
If ones car was so rusted around the vin plate... is it in the law that you could never restore the car b/c you would have to remove the vin? If you found a Judge that needed the firewall restored, is the Judge now of No value, b/c you couldn't even register it with the state if they believe you removed the vin for any reason? Even for restoration. Even if the hidden Vins match the the same VIN plate.
Josh.AZ.GTO is offline
post #2 of 2 (permalink) Old 09-23-2009, 02:39 PM
When I did my 66 frame-off I removed the data plate and VIN tag because I didn't want them damaged during blasting. I was able to find the factory correct rivets when I re-attached the plates. When I applied for my tag shortly after purchasing the car I had my local police department verify the vehicle and run the vin number.
I would ask this question of your local police department and have them verify the vehicle prior to removing the tags.
Just my humble opinion,
05GTO is offline
74 GTO Restoration - Odd Data Plate Code ra34inm 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 4 08-27-2009 08:25 PM
VIN vs Data Plate seawolf67 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 12-21-2008 09:06 PM
How To Read A Vin GTO JUDGE Service, Maintenance and Technical Discussion 0 08-05-2007 09:33 AM
Looking for a New GTO in the area PSU GTO 2004-2006 GTO General Discussion 22 06-27-2007 09:18 AM
My Dealership Experience Today in_burrito 2004-2006 GTO General Discussion 43 12-20-2005 05:14 PM
