vin rivets - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-02-2010, 09:39 AM Thread Starter
vin rivets
hi does any one know if the star rivets on the vin tag are seen from the top or the bottom with dash pad off thanks chuck. this is a 1968.
revup47 is offline
post #2 of 4 (permalink) Old 01-04-2016, 12:42 AM
Red1970GTO's Avatar
Check your Factory Assembly Instruction Manual. The '70 manual calls for the VIN Plate to be inserted from below the dash. HOWEVER, I've only seen a singe (1971 LeMans from Assembly Plant: Pontiac, MI) with them installed that way.
What's more, I've noticed that the Los Angeles plant ("Z") generally put the VIN plate on top of the dash prongs, whereas Baltimore ("B") put the plate under the prongs.
Go figure. It looks like some workers did it "right" and others did it the way they were OJT'ed
Red1970GTO is offline
post #3 of 4 (permalink) Old 01-19-2016, 09:24 PM
Which way the VIN rivets go in will depend on the assembly plant and in some cases, time of the year it was assembled, details like that, one can't just assume, it's like the '65 built A bodys that used a std rivet, I've seen somewhat seasoned GTO guys go nuts over '65's with std rivets. I looked last week at a '70 GTO convert built in Oct '69 out of Fremont land the orig star rivets could be seen from the top. One of my '71 Fremont A body's, they were installed from the bottom side.
post #4 of 4 (permalink) Old 01-20-2016, 01:55 PM
Juice564's Avatar
Quoted: 5 Post(s)
The star or rose pattern of the rosette rivet was visible from the top through the windshield on my '68 GTO. Have to look close but you can see the pattern.
Juice564 is offline
I Need Help with my VIN. Does anybody know.... 70Judge 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 8 12-15-2009 07:50 AM
vin # driver 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 02-28-2009 01:15 PM
vin # driver Member Introductions 0 02-27-2009 10:58 PM
'70 VIN decode??? silverjess 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 08-05-2008 07:17 AM
vin #1 G8 on ebay 06brazengto The Lounge 9 04-09-2008 07:02 PM
