Where to find engine numbers? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-18-2010, 06:19 PM Thread Starter
So my goats Trans and Engine are not the stock stuff, I know that for sure, my father had 4 gtos and a lemans at one point and switched engines/transmissions around depending which car was in better shape and which engine ran and whatnot.
So the question is a general one, where can I find where on the engine the numbers on, that will let me know what its from?
I'm 99% sure its a 389 from a GTO, which is what should of been in the 66 to begin with. The trans is a 4 speed manual, believe there was a 3speed in it when my pops got it.
So the engine and trans, where are the numbers so I can find out what they are exactly, and make sure they are something out of a GTO for sure.
Thanks all,
-Steve-
Artemis Entreri is offline
post #2 of 6 (permalink) Old 04-18-2010, 08:33 PM
68greengoat's Avatar
This should give you an idea where to look for codes.....
Pontiac Engine Codes
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 6 (permalink) Old 04-19-2010, 03:11 AM
Koppster's Avatar
....and here's another link with pretty much the same information in a searchable format
Pontiac Power
Koppster is offline
post #4 of 6 (permalink) Old 04-19-2010, 01:53 PM
Pontiachris's Avatar
look on the block near where a bellhousing would bolt to near the distributor and if your block is 70 or newer it should have the displacement stamped on the drivers side near the freeze out plug towards the front of the motor
Pontiachris is offline
post #5 of 6 (permalink) Old 04-30-2010, 05:00 PM Thread Starter
Thanks guys, I found the numbers 640106 on the block with YC under it, cant seem to find those numbers or what they mean, anyone have any ideas?
post #6 of 6 (permalink) Old 04-30-2010, 06:21 PM
640106 is the engine unit number which is similar to a serial number, the letter code YC was used for several years on b-body cars with a 2 bbl. The casting number you need is located on the distributor pad with the date code prior to mid year 1967 and then was moved to the rear of the block behind the #8 cylinder.
The block casting number for 65 and 66 (389) is 9778789 and 67 (400) is 9786133.
05GTO is offline
Engine Swap advice All numbers matching car Dirty Deeds 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 11 02-04-2010 12:07 PM
Engine Find (Once in a lifetime???) Lukeduk1980 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 06-29-2009 11:36 AM
Where can you find Pontiac engine paint? 70455goat 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 11 08-07-2008 05:31 PM
Is it possible to find an 05-06.... Matt37 The Lounge 7 11-28-2007 10:01 PM
Where can I find this? LYNMUP Intake and Exhaust Discussions 7 01-12-2007 10:14 PM
