093 Head Question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-08-2012, 11:53 AM Thread Starter
093 Head Question
Does anyone know where I could find push rod guide plates for a set of 093 cylinder heads?
HANK67 is offline
post #2 of 3 (permalink) Old 03-08-2012, 11:59 AM
Quoted: 100 Post(s)
These heads never had them.
post #3 of 3 (permalink) Old 03-09-2012, 10:25 AM
lars's Avatar
The 389 heads did not use guideplates, and did not need them due to the tight pushrod guide hole in the heads. If you want to use guideplates, you'll have to pull the heads and machine the stud bosses flat and co-planar: The 389 stud bosses are in the as-cast condition, so guideplates cannot be installed unless you machine the bosses flat and tap the holes for screw-in studs. With this all said and done, I'm not sure that you'll really gain much practical benefit from the guideplates, since a 389 with 093 heads is not likely to see power gains beyond 5800 rpm, making guideplates of little, if any, benefit.
Lars
lars is offline
Another HEAD question SDGoat619 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 0 02-29-2012 07:19 PM
Cylinder head question ROBSGTO Engine Discussions 30 04-20-2011 02:59 PM
Probably another dumb Head question Gertythadirtygoat Engine Discussions 6 12-30-2007 06:34 PM
Question on 04 GTO head gasket 06BLUEGTO Service, Maintenance and Technical Discussion 1 09-09-2007 08:12 PM
Head and cam question roadracer Service, Maintenance and Technical Discussion 2 03-07-2005 10:55 AM
