1967 HO engine - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-13-2016, 07:52 PM Thread Starter
Mathew Sokos's Avatar
1967 HO engine
Just found out from PHS that the orginal 400 engine in the 1967 GTO in the I am buying had a HO 400 with 360 hp with Safe T Track close ratio rear end with M21 transmssion. Bad news is the original engine is not in the car. Trying to return the car to as close to original as possible. Any help is appreciated.
MGS-67-GTO
Mathew Sokos is offline
post #2 of 3 (permalink) Old 09-15-2016, 03:09 PM
Quoted: 57 Post(s)
Looks like it could have had one of two casting number blocks-- 9792510 or 9786133.
Wallace Racing's Pontiac Engine Search
There are a couple of '67 blocks on Ebay. But they probably have the wrong 2-digit code on the front.
http://www.ebay.com/itm/CAL-1967-PON...-/252537542254
http://www.ebay.com/itm/1967-Pontiac...-/331966385327
Probably had #670 heads, and either a 744 or 068 cam. There are plenty of 670 heads for sale. But you'll need some with a casting date code earlier than the build date of your car, to be "numbers correct".
http://www.ebay.com/sch/i.html?_from...heads&_sacat=0
You can buy clones of the 744 & 068 cams. But they won't have the correct part number.
Had 2 different Q-jets for manual trans--7027263 & 7037263. Some of the prices for these old Q-jets are ridiculous, if they came on Musclecars, like Birds & Goats.There are usually some on Ebay, which may or may not be all original. Here's a couple of '67's.
http://www.ebay.com/itm/1967-Pontiac...3D281791265341
http://www.ebay.com/itm/1967-7027273...FV6cup&vxp=mtr
It'll cost you some extra $$ to buy all the correct # parts for your resto. It's up to you whether you think it is worth the price.
The intake was casting # 9786286. Here's one for sale on Ebay. But, it's WAY over priced. I think you can find one cheaper than that.
http://www.ebay.com/itm/1967-Pontiac...25.m3641.l6368
Some of these guys probably have one to sell. If not, you can find one over on the PY forum.
This guy may have one. He sells lots of Pontiac stuff, but can't list everything.
http://forums.maxperformanceinc.com/...d.php?t=781880
Need to use a thin stainless plate under the carb. If not, the "hot slot" will cause carb problems. It's best to plug the holes in the "hot slot", then use a stainless plate & the correct gasket. Here's a link to the explanation of this, from Q-jet guru Cliff Ruggles.
http://cliffshighperformance.com/sim...hp?topic=873.0
Ron's Pontiac Page: Pontiac Intake Manifold Part Numbers
Here's some of the stainless plates.
http://www.oreillyauto.com/site/c/de...1056&ppt=C0359
http://shop.advanceautoparts.com/p/f...RzkaAleL8P8HAQ
http://www.autozone.com/fuel-deliver...et/344021_0_0/
https://www.summitracing.com/parts/f...I44aAgXX8P8HAQ
http://www.ebay.com/itm/1965-69-STAI...-/261684991657
https://www.amazon.com/Fel-Pro-60731...art/B000C2CBZ8
http://quadrajetparts.com/quadrajet-...hick-p-97.html
http://www.ebay.com/itm/Quadrajet-Ca...25.m3641.l6368
https://www.summitracing.com/parts/hly-108-20/overview/
http://www.ebay.com/itm/Rochester-Ba...-/180242009213
If any of this Wallace info is wrong, I'm sure that Pinion head or some of the other guys can correct it.
Name:	'67 With Hot Slot.jpg
ID:	80810   Click image for larger version
ID:	80818   Click image for larger version
bigD is online now
post #3 of 3 (permalink) Old 09-15-2016, 09:35 PM
Quoted: 106 Post(s)
I have an early '67 Rochester carb I bought and rebuilt to run while Cliff had mine using his book.
It has been run on my '67 and works great, butterefies are nice and tight.
600 bucks shipped
ID:	80834   Click image for larger version
ID:	80842   Click image for larger version
ID:	80850   Click image for larger version
Goat Roper is offline
new engine warranty 1967 ? pony462 1964-1974 Tempest, Lemans & GTO General Discussion 6 03-24-2016 01:44 PM
1967 GTO Engine Question Partsguy19 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 08-07-2015 05:27 PM
Engine for 1967 GTO Mattzdad Pacific 2 07-16-2012 09:59 PM
1967 GTO engine Bad Banana 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 18 10-29-2009 09:19 PM
1967 400 engine ID confusion norcal65goat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 06-28-2009 05:32 PM
