1969 GTO 400 stroker question - Pontiac GTO Forum
post #1 of 6 (permalink) Old 08-13-2016, 08:05 PM Thread Starter
I have a numbers matching 1969 GTO 4-speed, 400 bored 0.030 over, RAIV cam & headers blah blah blah. It's time for a rebuild (last one was in 1980). I'm considering stroking it to a 461 and lowering compression a bit for today's gas (9.5/10.0 to 1 - currently 11+ to 1). Any disadvantage to doing this to my engine?
Thank you!
Andy Hughes is offline
post #2 of 6 (permalink) Old 08-13-2016, 08:37 PM
Quoted: 364 Post(s)
Thank you!
Nope.
post #3 of 6 (permalink) Old 08-13-2016, 09:51 PM
Quoted: 57 Post(s)
If that is the original engine, I'd stash it and build your stroker, using a 481988 block and 6x-8 heads.
Lots of guys will pay big bucks for cars with the original engine. But, if you are absolutely sure you'll never sell, then I reckin it don't make that much difference.
bigD is online now
post #4 of 6 (permalink) Old 08-13-2016, 10:27 PM
I stroked my numbers-matching original to 461, and I'm happy with the way it turned out.
post #5 of 6 (permalink) Old 08-14-2016, 02:20 PM Thread Starter
My GTO is the first car I ever bought, that was back in 1983. Probably not going to be selling it. Thank you for your response!
post #6 of 6 (permalink) Old 08-15-2016, 12:37 PM
Quoted: 100 Post(s)
There is no down-side to a properly machined and set up lower compression 461 based off a 400. More power, pump gas friendly, no need to rev to make a ton of torque. And with the right rear gear, likely no fuel mileage penalty, either, due to less throttle needed to get down the road. The danger of grenading your original engine with a stroker conversion is no greater than doing a standard rebuild on it, IMO, as long as the machine work meets specs.
400 Stroker Engine Build, Need Suggestions: Parts and Assemble jimmy328 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 01-16-2016 05:10 PM
Cooling for stroker question bondobill 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 11-28-2013 02:57 PM
Pontiac 455 stroker question chdu2686 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 06-23-2013 09:13 AM
400 block for a stroker speedracer25f 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 08-07-2012 12:20 PM
