1969 RA IV intake on standard 400 - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-02-2016, 07:43 PM Thread Starter
Osubucks999's Avatar
Hello
More for looks, I'm considering a RA IV intake on my stock 1969 GTO 400. Making a period correct run at a RA look.
Will the intake match up with the heads ok ?
Thanks for any help !!
Osubucks999 is offline
post #2 of 4 (permalink) Old 05-03-2016, 08:59 AM
Quoted: 4 Post(s)
The ports are slightly taller, but will work just fine. I ran one on a 455 bracket engine, with the 13, 16, 62, & 64 type, D-port heads. Didn't really run any quicker, but the intake was lots lighter, and cooler than the stock iron, since I did not use an exhaust heat crossover.
Obviously will work a little better with a good gasket match of heads and intake. But, not necessary. Don't know exactly how much power difference there would be. ? Probably never notice any difference, unless you had dyno or drag strip tests to measure it.
oldskool is offline
post #3 of 4 (permalink) Old 05-03-2016, 10:29 AM
For what a nice original '69 RAIV intake brings in the marketplace, one could have a pair of Dport heads professionally ported along with 16 new one piece stainless valves, and a quality valve job. Just throw this out, as have owned a few '69 RAIV intakes, and the JoeParts repro RAIV intake is a piece, have had several friends that bought the repro and were not happy at all with the misallignment of the ports and the plenum depth.
post #4 of 4 (permalink) Old 05-04-2016, 02:44 AM Thread Starter
Thanks for the replies.
I'll check the alignment and see how things go.
1969 400 rebuild help TLT3269 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 06-18-2012 09:16 AM
Horse Power Ratings for 1967 GTO "Standard" 335 HP 400 3rd1967gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 09-28-2011 07:28 AM
67 gto HO verse standard 400 value added ? fiesta62 1964-1974 Tempest, Lemans & GTO General Discussion 2 01-31-2011 05:06 PM
I need help with a 1969 400 Engine! gpm6367 Engine Discussions 1 02-19-2007 01:22 PM
