389 head gasket problem - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-04-2013, 08:18 AM Thread Starter
blm
Hi,
I have a 64 GTO 389 tri power.Motor has complete rebuild .060 over decked crack checked I have blown 2 head gaskets on the right side in less than 200 miles??? I do however have a header tapping on a cross member on this side. Could that cause a blown head gasket??? Thanks getting frustrated...
blm is offline
post #2 of 3 (permalink) Old 06-04-2013, 09:10 AM
No a header tapping on the cross member won't cause a head gasket to blow. If the block and head both are totally flat, I would replace the head bolts on that side and use a product like "Copper Coat" on both sides of the gasket.
post #3 of 3 (permalink) Old 06-04-2013, 09:28 AM
Quoted: 98 Post(s)
I suspect the machine work. Remove the head and check the block and head for trueness with a real straight edge.
Anyone know the head gasket bore required for 389 Willshire 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 13 07-26-2011 11:29 AM
head gasket Topkat 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 5 02-05-2011 10:33 AM
Blown head gasket? Supercharged fireside34 Engine Discussions 13 01-08-2011 10:24 AM
leaky head gasket Rocket2ya Service, Maintenance and Technical Discussion 4 06-20-2009 12:16 PM
Need Help - Blown Head Gasket Mike Kortney Engine Discussions 2 01-22-2007 01:42 PM
