65' convertible fuel line (3/8") - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-07-2018, 07:43 AM Thread Starter
Quoted: 126 Post(s)
I have been reading about the routing and challenges of running a new fuel line (while the body is attached to the frame) and have a simple question: why not just run the fuel line alongside the frame rail? Other than not being "factory", wouldn't this be easy to install and easy to service? One could even run a larger steel braided line or rubber line...
Just a thought / question...
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #2 of 2 (permalink) Old 06-07-2018, 11:31 AM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
It is also just as easy to put in a union and split the line so it runs in the proper place. If you engineer it right the union is invisible. Just...
WATCH OUT FOR LEAKS! CHECK IT MORE THAN TWICE!!!!
64GTOConvertible is offline
Installing 3/8" Fuel Line With Body on Frame aeconfidential 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 11-06-2015 11:01 AM
Brake line/ fuel line supplier greenjudge69 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 10-14-2015 07:44 AM
New Fuel Line? coolhandgoat Service, Maintenance and Technical Discussion 4 04-09-2007 01:22 PM
