67' 400 Cam Advice - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-23-2018, 01:56 PM Thread Starter
Nelson Musgrave's Avatar
67' 400 Cam Advice
I have a 65' Tempest with a 67' YT 400 with 670 heads and TH400. I purchased the car a year ago and have been driving it every day since. As far as i know it is stock and now i am having valve train issues so i feel like it is time to rebuild the top end of the motor. So i will be replacing cam, timing gear, lifters,springs, rockers and push rods. I want to drive it on the street 75% of the time and take it to the strip the other 25%. So I am looking for suggestions on cam kits. I was thinking this one https://www.summitracing.com/parts/cca-k51-240-4. Please let me know if this one would be good or should i go smaller on the cam.
1965 Pontiac GTO
400CI
Turbo 400
Nelson Musgrave is offline
post #2 of 5 (permalink) Old 06-26-2018, 08:28 PM
RMTZ67's Avatar
Quoted: 62 Post(s)
cam
look up the the 068 cam specs. that is a good choice. I just purchased one from a pontiac rebuilder on Ebay. fpaul is the name. I got my cam,double roller timing chain, oil pump,valve springs,lifters, studs, poly locks from him. Get on ebay punch in 068 cam and look for him. wealth of info.
RMTZ67 is online now
post #3 of 5 (permalink) Old 06-27-2018, 06:25 AM
Quoted: 54 Post(s)
That 292 Magnum cam would be real nasty in a street 400. Definitely NOT a good choice.
A Summit 2801 would probably be a decent street/strip choice, and about the cheapest thing out there. It's sorta like a higher lift version of the Pontiac 068 cam.
https://www.summitracing.com/parts/sum-2801
Next thing up from that would probably be something like a Lunati 10510312.
http://www.lunatipower.com/Product.aspx?id=1759&gid=278
Then a Summit 2802 is another step up.
https://www.summitracing.com/parts/s...RoCJdgQAvD_BwE
Here's a Crane & a Howards, in that same neighborhood.
https://www.summitracing.com/parts/c...IaAusEEALw_wcB
https://www.summitracing.com/parts/hrs-410141-12
Bigger cams will give you more top end power, but a rougher idle, and less low end torque & vac.
https://www.crower.com/camshafts/pon...m-284-hdp.html
https://www.summitracing.com/parts/h...w/make/pontiac
bigD is online now
post #4 of 5 (permalink) Old 06-29-2018, 11:51 PM Thread Starter
ok thank you for the information!
1965 Pontiac GTO
400CI
Turbo 400
post #5 of 5 (permalink) Old 06-30-2018, 06:17 AM
Quoted: 36 Post(s)
Not offering advice, but instead, sharing an experience. I recently installed a Lunati Voodoo 262/268 in my '71 GTO with a stock 400 engine. This cam serves my purpose, but I really don't have anything to compare it to. The motor runs well and has adequate power, but I do think it is a little sluggish. Maybe not the cams fault. Good idle and response. About 17-18 inches of vacuum. This cam came highly recommended by a few who I admire and respect their advice. I have no regrets. The cam I removed was also a Lunati. High performance. Thought it was choking the engine. Best wishes with your selection.
Nicholas is offline
67 Pontiac 400 w/670 heads. Need Advice Nelson Musgrave 1964-1974 Tempest, Lemans & GTO General Discussion 4 08-10-2017 10:07 AM
Cam and head install help and advice mr.gto Engine Discussions 4 04-18-2010 11:06 PM
Advice - How to wake up my '72 400 2bbl jpdog357 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-30-2007 08:01 AM
comparison the "cant break 8s" b4 advice and after the advice DK2F Service, Maintenance and Technical Discussion 0 02-11-2006 03:09 AM
