67 400 Man Tran Carb Choice - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-16-2018, 10:06 PM Thread Starter
Hey guys.
So I have a my 400 back together, 67 400 with a HO cam in it. I need a carb and I really can't dedicate the funds to buy an original quadrajet carb that is missing from my engine. What is the best alternate carb? Any hands on experience would be great.
DCRT68 is offline
post #2 of 5 (permalink) Old 05-16-2018, 11:15 PM
'Most likely I would go through a 7029262 or 7040262 Q-jet and plug the vac modulator port. both are relatively inexpensive as nice cores and will bolt right up in place of a very expensive real 7027263.
If many future performance mods were being planned, would begin with a '76-79 M4MC style Pontiac, Olds or Buick Qjet and would go through a host of mods. Cliff's book on Rebuilding and Modifying Rochestor Quadrajets is a must read!
post #3 of 5 (permalink) Old 05-16-2018, 11:18 PM
Quoted: 73 Post(s)
A '68-'69 Pontiac Q-jet would work & look very similar, as would a '70 non-Calif Q-jet.
If you wanna take a chance on an Ebay seller:
https://www.ebay.com/itm/Pontiac-Qua...cAAOSwns1a4ycv
https://www.ebay.com/itm/1970-Pontia....c100005.m1851
https://www.ebay.com/itm/1970-PONTIA...wAAOSwzXxaC2S-
https://www.ebay.com/itm/OEM-1968-68...gAAOSwhZ9a6NDC
https://www.ebay.com/itm/Carter-Quad...8AAOSw0XFa54ob
A late '60's/early '70's Buick Q-jet will work, and most models will be cheaper than the Pontiac models, especially if the Pontiac carb came on a GTO or Bird. The Buick carbs have a different throttle lever, but can be rigged up, just as required when switching to a Holley or Edelbrock.
https://www.ebay.com/itm/1973-BUICK-....c100752.m1982
https://www.ebay.com/itm/1969-BUICK-...IAAOSw8A1aVUDw
Some like the '76-'79 800cfm models. The 403 Olds Q-jets will work, but the later carbs don't look like the '67-'70 models.
https://www.ebay.com/itm/PONTIAC-TRA...AAAOSwhHlaoEvu
If you don't mind the look and extra plumbing needed, for the side inlet, you can use a Chevy or Edelbrock Q-jet. The Edelbrock Q-jets are much newer, having been built in the '90's & early 2000's.
http://www.carburetion.com/Rochester.asp
https://www.ebay.com/itm/Edelbrock-1...gAAOSwubRXM279
As PH said, if you can rebuild your own Q-jet, you can save some bucks. If not, you'll have to buy one that somebody else rebuilt. There is some real junk out there. Don't know your budget. If you can spend $400-$500, here are some rebuilders who have good reps. NO, I haven't bought from any of these guys Did my own. Just going by online info, for rebuilder info.
https://www.smicarburetor.com/produc...D2/9/sfID3/100
http://quadrajetpower.com/quadrajets...ready-to-ship/
http://www.everyday-performance.com/
As I've probably mentioned several times, the '70 Pontiac Calif model, & all(I assume) '71-'79 Pontiac Q-jets have the big "smokestack" vent, requiring a hole for it, in the air cleaner base. Other GM Q-jets do not have this big vent.
https://www.ebay.com/itm/1973-pontia...AAAOSwWY5akvHY
https://www.ebay.com/itm/1974-704426...cAAOSwT-FZC226
https://www.ebay.com/itm/1976-76-Pon...cAAMXQVT9SseAu
Just thought about the fact that some 301 Q-jets did not have the big vent.
http://vi.raptor.ebaydesc.com/ws/eBa...00354000&ver=0
ID:	111785   Click image for larger version
bigD is online now
post #4 of 5 (permalink) Old 05-17-2018, 11:25 AM Thread Starter
Thanks for the info guys! Alot of information. With using any of the mentioned later carbs(68,70, 74) are there many issues with hood clearance and fitting on the original 67 gto air cleaner?
Also, I think i might actually have a 74 carb. I have to look as the car had some 70s carbs in the trunk when I got it. I'll post some serial numbers
DCRT68 is offline
post #5 of 5 (permalink) Old 05-17-2018, 11:44 AM Thread Starter
Big D. Do you know if I buy a 68 quad,like 7028262. Do I need to worry much about the specifications of manual or auto trans. The link you sent of the Ebay carb, shows H.O application, but can't read anything on Man, Auto specifications.
DCRT68 is offline
67 400 Timing/Carb Help AKGTOJoe50 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 5 06-08-2016 10:00 PM
what carb for '67 400? smythe 1964-1974 Tempest, Lemans & GTO General Discussion 9 09-20-2015 12:14 PM
Correct carb for 400 HO Brad 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 12-20-2012 09:59 PM
1970 400 Carb Change LCplOsborne 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-14-2009 10:09 AM
