67 ho exhaust manifolds aftermarket best ones available? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-30-2011, 08:10 PM Thread Starter
fiesta62's Avatar
hi, i am interested in finding original ho manifolds for my 67 gto but i have learnt repros have the casting codes so possibly there is a good set of repros made that would be the same as originals and just as good, but i know originals have built in pass plates and also the heat riser , does anyone know what are the best aftermarket ones available?....and do they have pass plates and heat riser built in?....thanks
fiesta62 is offline
post #2 of 6 (permalink) Old 10-30-2011, 10:23 PM
FNG69's Avatar
I’ve looked at the sales brochures, shop manual, restoration guide, etc… I cannot find a picture of the heat riser set up on a factory HO (or Ram Air) exhaust manifold – the Ram Air restoration guys say that the “boss” is there on the reproduction casting for the heat riser, but It looks like the “boss” is set up so that the flapper would be on the front of the manifold, not on the side; that would put the spring on the back of the manifold, and I cannot imagine that is correct..
Guess I'm saying we both could use some help on these?? Thanks, Les
FNG69 is offline
post #3 of 6 (permalink) Old 10-31-2011, 08:01 AM
RIP (12/27/60-7/18/15)
Topkat's Avatar
I believe OPGI was the correct manifolds.
the spring in on outside of the passenger side
good luck
Topkat is offline
post #4 of 6 (permalink) Old 11-15-2011, 09:14 PM
No idea about the heat risers. Never seen them in the originals. Whatever RA manifolds you get, plan on taking them to the machine shop and have them surface plated flat. This will allow you to install them on the heads without anything but a thin bead of silicone. no gaskets required. Also, may need to port them to get the ports to line up
old66tiger is offline
post #5 of 6 (permalink) Old 11-15-2011, 11:44 PM Thread Starter
fiesta62's Avatar
hi, my 67 is a ho so the ports will be fine, i have found a set of original ho manifolds with the heat risers and correct codes so all good, bit of rust but nothing a clean up wont fix, not sure if i need to re- surface them as you suggest, i figured i will just use a gasket thats the usual way isnt it ?...
fiesta62 is offline
post #6 of 6 (permalink) Old 11-19-2011, 08:03 AM
RA6T7GTO's Avatar
Send a message via AIM to RA6T7GTO
always a good idea to make sure the gasket surface is flat, these original manifolds are old and im sure they are warped from heat and age, put them on a belt sander to clean them up
RA6T7GTO is offline
65 Ram Air Exhaust Manifolds Purple Haze 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 05-09-2011 06:22 PM
exhaust manifolds Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 11-17-2010 11:54 AM
Exhaust Manifolds texasgto 2004-2006 GTO General Discussion 1 02-22-2005 11:36 AM
