68 gto timing issues - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-27-2018, 04:22 PM Thread Starter
frankie68's Avatar
Quoted: 6 Post(s)
Hello again. I have a 68 gto with the 400 pontiac mill. I've recently attempted to set the timing but wondered why after setting initial timing will it under throttle retard itself instead of advancing it.
Anyone ever have any issues like this
frankie68 is offline
post #2 of 3 (permalink) Old 06-27-2018, 07:33 PM
Did you set the timing with the vacuum advance still connected? If so, don't -- disconnect and plug the vacuum line before setting timing. Also, if you have your vacuum advance connected to an unported manifold vacuum source, then what you're describing is normal. An unported source presents vacuum to the advance mechanism all the time, even at idle, so it will be adding some advance via the vacuum diaphragm. When you blip the throttle, vacuum will drop initially and can cause what you're seeing.
post #3 of 3 (permalink) Old 06-28-2018, 04:42 PM Thread Starter
frankie68's Avatar
Quoted: 6 Post(s)
Ya has nothing to do with vacume connected or direct and/or manifold vacume. Timing was taken with vacume fully disconnected and plugged but thank you for the suggestion.
Anyone else with some ideas. Was thinking a slipping harmonic balancer?
1968 GTO set base timing and total timing?? rob40999 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 15 05-27-2018 07:37 AM
Timing Issues on 67 400 GTO Richard Painter 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 5 02-28-2017 07:24 PM
Setting the Timing-68 got hayes68gto 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 07-08-2013 09:42 AM
68 Timing Problem 428ci goatmaster428 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 09-07-2009 05:05 PM
