cam? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 06-27-2013, 09:34 PM Thread Starter
maktope's Avatar
cam?
My last post was what to do with my car. Well I figured it out rearend of course, going to take the duel quads off put a single 4bbl on. And a roller cam. I want a very aggressive street cam. Getting lost in numbers. Any recommendations
maktope is offline
post #2 of 8 (permalink) Old 06-28-2013, 10:26 AM
More info is needed, like engine details, what trans, rear gear, what you plan on doing with the car, etc.
post #3 of 8 (permalink) Old 06-28-2013, 12:04 PM
Quoted: 100 Post(s)
X2, in spades. Your question is as vague as "what's good to eat?"....
post #4 of 8 (permalink) Old 06-28-2013, 04:08 PM Thread Starter
maktope's Avatar
428, muncie m20. Putting 3.42 gears in. Mostly street occasionally strip.
maktope is offline
post #5 of 8 (permalink) Old 06-28-2013, 04:37 PM
What else has been done to the engine? What heads? What compression ratio are you running? You can't give too much info here, the more we know the better off you'll be in the long run.
post #6 of 8 (permalink) Old 06-28-2013, 06:34 PM
Quoted: 100 Post(s)
X2. Compression ratio and head type/flow is critical when choosing a cam.
post #7 of 8 (permalink) Old 06-28-2013, 06:55 PM Thread Starter
maktope's Avatar
Sorry for the vagueness, its a 1969 428 bored .030 over with 1970 455 #64 heads, mechanically thats about it for upgrades, it ofcourse has duel quads on at the moment but those are coming off. The Current cam in it is either factory like in kind out of a 428 or a 455, the paper work from the PO is kinda sloppy on a few things. The motor was rebuilt about 8k miles ago, 2 years. Power i have no clue how much it makes, seeing i bought it from him after he snapped the rear axle on it. From the looks of things it has a very very nasty case of wheel hop. So i am putting in a GM 12 bolt, changing suspension, he also floated some lifters. Since its going to be in the shop i am having the whole motor gone through. But since its going to be pulled i am having some work done to it. Figured roller cam and everything that goes with it. Like everything else i am on a budget so i am unavailable to do everything i would like but thats my start.
maktope is offline
post #8 of 8 (permalink) Old 06-28-2013, 07:21 PM Thread Starter
maktope's Avatar
As for compression, the paper work i have says 10.5/1 Normally i wouldnt doubt that, but there has been about 8 things ive swapped out already that were different from the paperwork. And i know Rukee you've commented on my other posts, and probably are laughing to yourself because i've been all over the map on this car so far. Its just theres so much i would like to do.And so many ideas from friends and on here. But i have eliminated many of those ideas. And sticking with the rear end carb and cam for this year.
maktope is offline
LS1 stock cam VS LS2 stock cam Ehrgeiz X 2004-2006 GTO General Discussion 5 02-14-2014 05:20 AM
Cam Chose ms4 vs livernois strage 2r cam GTOMOE9 Engine Discussions 7 03-08-2011 10:20 PM
cam ?s dieseltweaker Engine Discussions 4 02-07-2010 09:40 PM
cam jschmitty19 Engine Discussions 1 12-18-2009 06:36 AM
best cam reidlou29 Engine Discussions 7 05-14-2009 08:42 AM
