cam bearing too tight? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 04-13-2012, 04:39 PM Thread Starter
Hello guys, I had my block mic'd and honed and new cam bearings installed. I put the old cam in just to check fit (oiled everything well first) and it fit pretty tight on two of the bearings. I don't think it's a alignment thing. The first two bearings just seem tight. By tight I mean I put a torque wrench on it and it took about 20 lbs to turn it. I was advised to use some fine emory cloth on the bearings to gain more clearance. Is this a good idea? I am worried I could get some of the particles in the oiling paths. Thanks,
67lemans is offline
post #2 of 7 (permalink) Old 04-13-2012, 05:27 PM
Quoted: 100 Post(s)
DON'T emory cloth or sand/dress down the bearings. They might be installed incorrectly or slightly crushed. Have the shop that did the work re-do the bearings. This is not a place to "wing it". JMHO...........
post #3 of 7 (permalink) Old 04-13-2012, 06:14 PM
and don't check the fit with a cam you arent gonna use!
Eric Animal is offline
post #4 of 7 (permalink) Old 04-13-2012, 07:46 PM
It'd be a good idea to let the shop that installs the bearings also have the cam you're going to run. When you return to pick up the block, don't accept it until you've checked to make sure the cam spins freely yourself.
post #5 of 7 (permalink) Old 04-14-2012, 06:56 AM Thread Starter
Thanks, that all sounds like good advice, I'll heed it.
67lemans is offline
post #6 of 7 (permalink) Old 04-14-2012, 03:47 PM
Yeah, the machinist I use always recommends sending the cam I'm using in with the block to fit it.
post #7 of 7 (permalink) Old 04-20-2012, 08:17 PM Thread Starter
This worked out just as planned. They had to "ream" a couple of the bearings a little and it is now much better. Put the cam in, make a few adjustments, repeat step one, etc. No charge even. Thanks for the recomendations
67lemans is offline
Throwout bearing?? gggto Service, Maintenance and Technical Discussion 1 12-31-2011 08:50 AM
wheel bearing nut Topkat 1964-1974 Tempest, Lemans & GTO Wheels & Tires 6 04-05-2011 03:50 AM
pot hole fix are front ends that tight speedydog5 Drive train, suspension, alignment and brakes. 6 12-10-2009 08:32 AM
how tight to torque the lug nuts?? Bowdy's GTO 2004-2006 GTO General Discussion 4 01-04-2008 06:24 AM
Tight Shifter Boot? GM Kid 2004-2006 GTO General Discussion 16 06-28-2005 03:00 PM
