Cam Id help - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-18-2015, 12:28 PM Thread Starter
bobby326's Avatar
Cam Id help
I have a cam that I took out of my 326 and I can't figure out what cam it is. I bought the lemans in 2002 so I'm not sure how old the cam is. Markings on the cam. CMC prob stands for cam manufacturing company. In between the next cam lobe were its stamped cmc is 1805. On other end of cam were the thrust plate bolts to on end face is 201056. Also stamped USA in between cam lobes by CMC. The engine was a 67 326 140-heads with 7/16 screw in studs. Turbo350 with 12bolt 411 gears. Previous owner raced it with nitrous. Cam sounded great with nice Lopey idle to it. Replaced cam with comp xe262 and full comp valve train. Just want to know if I went up or down with cam. Thanks for any help.
bobby326 is offline
LS1 stock cam VS LS2 stock cam Ehrgeiz X 2004-2006 GTO General Discussion 5 02-14-2014 05:20 AM
What Cam should I use? smac8876 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 5 08-22-2013 07:40 AM
cam? maktope 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 7 06-28-2013 07:21 PM
Cam Chose ms4 vs livernois strage 2r cam GTOMOE9 Engine Discussions 7 03-08-2011 10:20 PM
Cam Help Mike_V Engine Discussions 10 12-10-2006 12:49 PM
