Cam identification - Pontiac GTO Forum
 1Likes
  • 1 Post By PontiacJim
post #1 of 4 (permalink) Old 08-08-2018, 08:52 PM Thread Starter
1970PA4lifelemans's Avatar
Quoted: 6 Post(s)
400, 62 heads, pulled cam to see what was in it. Rear of cam. R 142 4 then 28 46 91 behind front bearing 540 233 letters CWC, between lobes starting at distributor 51, F1, 5,4,0
1970PA4lifelemans is offline
post #2 of 4 (permalink) Old 08-08-2018, 08:57 PM
Quoted: 347 Post(s)
Originally Posted by 1970PA4lifelemans View Post
400, 62 heads, pulled cam to see what was in it. Rear of cam. R 134 4 then 28 46 91 behind front bearing 540 233 letters CWC, between lobes starting at distributor 51, F1, 5,4,0
Pontiac typically put a letter code on the front snout of the cam. CWC is the foundry casting manufacturer. Unknown on the rest.
post #3 of 4 (permalink) Old 08-09-2018, 09:33 AM Thread Starter
Quoted: 6 Post(s)
By snout do you mean the distributor end or timing end? I found the R 142 with a tiny 4 stamped next to it on the distributor end
post #4 of 4 (permalink) Old 08-09-2018, 08:20 PM
Quoted: 347 Post(s)
Front of the cam where the timing gear goes on. You may have an aftermarket cam and it can be very hard to ID it without using a degree wheel and dial indicator to measure total lift.
BearGFR likes this.
to cam or not to cam Mayhem5417 Service, Maintenance and Technical Discussion 12 09-26-2018 03:20 PM
LS1 stock cam VS LS2 stock cam Ehrgeiz X 2004-2006 GTO General Discussion 5 02-14-2014 05:20 AM
need help! cam or no cam! blackbeast Engine Discussions 4 02-17-2013 09:23 PM
Cam Chose ms4 vs livernois strage 2r cam GTOMOE9 Engine Discussions 7 03-08-2011 10:20 PM
Pontiac Engine Identification megavars 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 12-03-2004 06:33 PM
