cam specs - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-12-2011, 09:34 PM Thread Starter
cam specs
What are the cam specs for a ram air 3 and ram air 4 . My engine was rebuilt with a hydraulic roller with a 446 in. lift cam I am seriously considering a set of d port edelbrocks over the summer I think in the past I have read a famous 068 pontiac cam was similar to 446 inch lift .
68gtohawk8369 is offline
post #2 of 4 (permalink) Old 11-12-2011, 11:56 PM
RAIII specs are 301/313 .410/.410 119 LSA
RAIV specs are 308/320 .470/.470 114 LSA
068 specs are 288/302 .410/.410 116 LSA
You can get a .447 lift on the 068 and RAIII by using 1.65:1 rockers.
05GTO is offline
post #3 of 4 (permalink) Old 11-13-2011, 08:06 AM
66tempestGT's Avatar
if i was going to spend that kind of money on some modern cylinder head technology would wave goodbye to the antique camshaft grinds also.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #4 of 4 (permalink) Old 11-13-2011, 12:43 PM
- And that's what I did on my 69, even with round port iron heads.
68gtohawk8369, keep in mind that all the "old" cam profiles were designed when octane was freely available, the fuel had lead, and cylinder pressure wasn't a concern beyond the idea that "more is better". I'm not saying those factory cams were "bad" - they were very good - for the time and the situation. In fact if you compare the specs on the Ram Air IV cam and the SD455 cam, you might find some striking similarities (can you say, same?)
Today we've got to worry big time about cylinder pressure (at least on gas) because of fuel quality. The game has changed. Lead is also history and with it the protection/lubrication for exhaust valve seats as well as the effect on octane rating. Modern cam designs take all that into consideration while still trying to deliver profiles that make good power, and many of them do a very good job of that. Plus in the 40+ years since those original cams were designed, we've learned a few things and are able now to simulate and model (due to computers and software) and directly observe what's actually going on inside an engine with much more detail and accuracy than was possible back in the 60's.
BearGFR is online now
GTO can specs Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 09-12-2010 03:09 PM
Help With Cam Specs AGETECH 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 05-23-2010 03:58 PM
65 GTO engine specs trimfixer 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 10-08-2009 09:51 PM
Manufacturer 0-60 specs daredevil1 2004-2006 GTO General Discussion 9 07-16-2009 07:54 PM
05 GTO Auto 0 - 60 Specs Nightshifter Service, Maintenance and Technical Discussion 3 07-01-2005 07:53 AM
