Carbon on piston tops - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-19-2016, 12:34 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
I had to remove both heads from my 1974 350 to have broken exhaust bolts removed. While I have the heads off, any suggestions for a good way to remove carbon deposits from piston tops without removing the pistons or further engine tear down? Only 28,000 miles on the engine.
Thanks.
Red74Goat is offline
post #2 of 7 (permalink) Old 05-19-2016, 06:23 PM
Quoted: 361 Post(s)
Thanks.
I don't think I would mess with it. You really don't want to be breaking loose carbon deposits that may fall between the sides of the piston and the cylinder walls and score them up upon start-up or worse, get lodged in the ring lands.
If you gotta do it, I would have a vacuum running as I scraped to draw up the loose stuff so it got sucked up immediately.
post #3 of 7 (permalink) Old 05-19-2016, 07:39 PM
Just use some sea foam in the gas tank after you get it together, that will clean it up.
post #4 of 7 (permalink) Old 05-20-2016, 12:20 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
Jim and Rukee, thanks for the recommendations. I'm not set on cleaning the piston tops up right now, just thought it might be worthwhile with the heads already off.
I always worry about any initial project getting farther and farther from the original intent ... next thing you know a 2-3 week project turns into 2-3 years and a "project car" for sale on craiglist.
At this point, I'm likely to just paint the heads, intake manifold, valley pan, etc. put on new gaskets all around, do an oil change and get her started and going.
Have either of you pulled the coolant drain plugs from the engine block and then done anything when reinstalling the plugs, like using any kind of non-hardening sealant, wd-40, or teflon tape on the plug threads before reinstalling? My plugs came out pretty easily, but had some surface rust on them.
Thanks.
post #5 of 7 (permalink) Old 05-20-2016, 07:18 AM
Teflon tape, be sure to wrap it clockwise when looking at the bottom of the plug so the tape doesn't unwrap as you put it in.
post #6 of 7 (permalink) Old 05-20-2016, 08:32 AM
I prefer Teflon paste.
post #7 of 7 (permalink) Old 05-20-2016, 02:38 PM
Quoted: 98 Post(s)
X3 on not scraping the carbon. Use Seafoam or run ATF through the carb at about 2500 rpm in neutral. I use gasgasinch on freeze plugs, or nothing at all. I also use brass plugs, so they never rust out. I would not use teflon tape, personally....too slick. Thread sealer? Perhaps.
Screaming Goat with T-Tops ConnieCadillac Exterior Discussions 7 07-06-2015 04:52 PM
Baer 11" 2-piston discs vs. stock single piston Jeff's Classics 1964-1974 Tempest, Lemans & GTO General Discussion 8 06-29-2010 07:27 PM
T tops GTOhhh 2004-2006 GTO General Discussion 3 04-30-2007 06:07 PM
T Tops whoisthepac Exterior Discussions 8 01-18-2007 04:13 AM
