carburetor tool for tri-power - Pontiac GTO Forum
post #1 of 11 (permalink) Old 08-10-2018, 12:48 PM Thread Starter
Does anyone make a tool to adjust the idle screws on a 65 tripower center carb? I have a buddy with a flexible screwdriver from the 1960s that will fit around the front carb and it works well. I've looked everywhere and all the flexible screwdrivers now come with a 1 1/2 inch socket adaptor on the end for different bits and it won't bend enough on the end to reach the screws.
grotto107 is offline
post #2 of 11 (permalink) Old 08-10-2018, 05:45 PM
Quoted: 347 Post(s)
This one sure looks like it would work. Might have to grind down the bit end where it seats into the flex shaft, but I don't see why it would not work? https://www.homedepot.com/p/Stalwart...FUwLDAodyNUABw
post #3 of 11 (permalink) Old 08-10-2018, 06:02 PM
Quoted: 98 Post(s)
I have one. The same one I've had since 1981. It's made by Blue-Point (Snap-on). It comes with various socket ends...slot head, hex, even an allen for dwell adjustment on GM distributors. Have used it a thousand (or more) times on as many cars. Really gets in there with ease on any tight carb set-up.
post #4 of 11 (permalink) Old 08-10-2018, 07:01 PM
My65goat's Avatar
Quoted: 18 Post(s)
I bought one from Napa but it didn't work. I have a very skinny flat head with a long shafts that works for me. It's one of those screwdrivers that looks like it belongs in the trash can but it has its purpose, lol.
My65goat is offline
post #5 of 11 (permalink) Old 08-11-2018, 04:29 AM Thread Starter
I've tried 3 of those with the Home Depot type socket and they just won't squeeze in there behind the front carb.I'll try the Blue Point.
Many thanks!
post #6 of 11 (permalink) Old 08-11-2018, 08:29 AM
Quoted: 126 Post(s)
Curious what you find as I have been struggling with the same problem....After I rebuilt the carbs I added the port for brake vacuum and installed the factory brake vacuum line off the front carb, making the adjustment even harder.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #7 of 11 (permalink) Old 08-11-2018, 08:39 AM
Quoted: 106 Post(s)
I don't know if this will fit in the space but this is what I have, I can adjust the Quadrajet with the air cleaner on with this unit.
https://www.ebay.com/p/Snap-on-2006I...et/26017014773
Goat Roper is offline
post #8 of 11 (permalink) Old 08-15-2018, 06:02 PM
Quoted: 98 Post(s)
Goat Roper, that's exactly the one I've been using for the past 37 years. And back then, I paid about $60 for it, so for $69 in 2018, it's a heck of a good deal. It really does a great job on tight screws, and makes dwell adjustment a snap.
post #9 of 11 (permalink) Old 07-20-2019, 03:42 PM
baba67's Avatar
Tri-Power carb adjusting
I had the same issues with my 66 tri-power setup.
This is what worked for me.
I really am happy with it.
Motion Pro 08-0229 1/4" 90 Degree Hex Driver
Name:	Carb Adjuster Tool.jpg
baba67 is offline
post #10 of 11 (permalink) Old 07-20-2019, 07:26 PM
Lemans guy's Avatar
Quoted: 54 Post(s)
yes I use that same snap on tool, and as Geeteeoh said, ...............works on dwell adjustment as well......
Lemans guy is offline
Running a built 421, 65 GTO, Tri-power, considering a 66 Tri-power setup avman 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 4 07-28-2018 10:46 AM
Power Brakes with Tri Power timmyg 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 08-21-2013 03:10 PM
Tri-carb carburetor differences 65GTO421HO 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 06-26-2009 07:52 PM
