Catalina 400 with 14 heads - Pontiac GTO Forum
 2Likes
  • 1 Post By bigD
  • 1 Post By bigD
post #1 of 5 (permalink) Old 03-05-2018, 09:08 AM Thread Starter
Quoted: 162 Post(s)
I have a motor that appears to have come out of a 68 Catalina - 400 with 14 heads. According to my research this was a low compression motor that produced only ~265 hp. That said the previous owner setup the tri power on the car and might have done a cam as I cannot find a vacuum leak and am only getting 11 - 12" vacuum. (Car idles like butter and pulls hard to 5k.)
My question is how did standard GTO 77 head gain ~100 hp over the 14? According to Wallace Racing's compression hp calculator , the increased compression of the 77 head certainly should not have been that much. The 77's had 1.92/1.60 valves and 10.5 c.r., whereas the 14's had 1.96/1.66 valves and 8.6 c.r. I've been told that the heads for the most part are all the same (minor differences), with the exception of a few special high compression heads. So does that mean the original cam in this motor was a stump puller? Can much (50+ hp) of the "lost hp" be gained by a better cam?
Thanks in advance!
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #2 of 5 (permalink) Old 03-05-2018, 04:09 PM
Quoted: 73 Post(s)
"...My question is how did standard GTO 77 head gain ~100 hp over the 14..."
The engine with #14 heads had less compression(less than 9:1), and came with a 2-barrel carb & small cam.
http://www.wallaceracing.com/enginesearch4.htm
"...Can much (50+ hp) of the "lost hp" be gained by a better cam?..."
It's possible, depending on how small the old cam is, and how correct for the engine the "better" cam is. A small Voodoo cam, such as a 256 or 262, will increase cylinder pressure, vac, and power/torque in the lower rpm range, compared to a cam with too much duration.
http://www.lunatipower.com/Product.aspx?id=1774
http://www.lunatipower.com/Product.aspx?id=1775
These cams will also require stronger than stock valve springs.
deanhickey likes this.
bigD is online now
post #3 of 5 (permalink) Old 03-06-2018, 08:11 AM Thread Starter
Quoted: 162 Post(s)
Wallace Racing's Pontiac Engine Search
Voodoo Hydraulic Flat Tappet Cam - Pontiac V8 256/262 - Lunati Power
Voodoo Hydraulic Flat Tappet Cam - Pontiac V8 262/268 - Lunati Power
Thanks BigD !
Any thoughts on the Comp Cams XE series ?
My car is a manual with a 3.55 rear and 26" tire/wheel package. Generally I am in the 2,500 + rpm range and love to let her run hard to 5500. Thanks again for your help.
Current setup:
4 speed Muncie
cij911 is offline
post #4 of 5 (permalink) Old 03-06-2018, 02:25 PM
Quoted: 73 Post(s)
"...Any thoughts on the Comp Cams XE series ?..."
Don't recommend 'em at all !
Most Pontiac guys that have tried one said they make lots of unwanted noise, because they slap the valves shut too hard. This is because of the very aggressive closing ramps. They also have a 110° LSA. The smaller Voodoo cams, have a 112° LSA, which many Pontiac engine builders like better for street engines, especially those smaller than 455 cubes.
The Voodoo cams have a milder closing ramp, eliminating the extra noise.
cij911 likes this.
bigD is online now
post #5 of 5 (permalink) Old 03-06-2018, 09:49 PM Thread Starter
Quoted: 162 Post(s)
Thanks!
Current setup:
4 speed Muncie
cij911 is offline
#13 or #48 heads for a 400? SPCMarty 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 11 04-08-2012 06:14 PM
got my new poncho 400 heads skuzzzusmcdevildog 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 02-29-2012 10:11 AM
# 11 heads on a 400? Seol21 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 04-06-2011 09:40 AM
which heads to pic for my 400 bobby326 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 07-20-2010 06:12 PM
'67 400 Heads on '66 389 PaulPaladin 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 04-05-2006 11:55 PM
