Center carb throttle body - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-28-2018, 02:36 PM Thread Starter
The center carb throttle body binds the throttle shaft when tightened onto intake causing the throttle to stick. When I loosen the nuts connecting throttle body to intake the throttle shaft moves freely as it should but it seems the nuts aren't tight enough. Any thoughts?
Hotsticker1 is offline
post #2 of 2 (permalink) Old 05-29-2018, 06:50 AM
Quoted: 126 Post(s)
Are the blades hitting the base of the carb? What is actually binding ? If you take the airhorn off, you should be able to see what is happening.
I can't think why tightening the carb to the intake would create a problem unless the intake holes are not aligned properly with the carb blades.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
3x2 center carb for 65 68goatconvt 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 05-04-2018 08:09 AM
66 tori power center carb Familytradition 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-15-2015 03:55 PM
what goes here behind throttle body crustysack Engine Discussions 2 02-27-2010 12:34 AM
05 throttle body tlcmetrokc Intake and Exhaust Discussions 0 07-09-2006 07:29 PM
throttle body badtmpdgoat Service, Maintenance and Technical Discussion 1 11-14-2004 09:10 PM
