coil? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-29-2017, 11:04 AM Thread Starter
Quoted: 9 Post(s)
coil?
I was timing my 1971 400, and when i was turning the distributor, my hand touched the negative wire on the coil and I could feel a slight tingle of electricity. Is this indicative of a bad coil? or possible something else. Put in a rebuilt points distributor a couple of months ago, and I have verified that the dwell is correct and timing is as well. Your thoughts are appreciated
ajluzi1957 is offline
post #2 of 4 (permalink) Old 04-29-2017, 04:15 PM
Quoted: 347 Post(s)
You're good. Try touching a spark plug wire near a spark plug while the engine is running, now that's a tingle you won't forget. LOL Cool little You Tube video on how it all works:
post #3 of 4 (permalink) Old 04-29-2017, 10:11 PM
Charles Rummel's Avatar
Sounds like the coil has a minor internal short you shouldn't get shocked touching ground. I would replace it if budget allows. If it's not the coil and it still happens keep your receipt and the box. Cool places sometimes will give you back a credit to buy your next part.
Charles Rummel is offline
post #4 of 4 (permalink) Old 04-30-2017, 06:48 AM Thread Starter
Quoted: 9 Post(s)
Thanks to both of you. I will change it and keep the old as a spare
Coil Over Springs knucklehead12 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 04-01-2015 09:19 PM
coil Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 07-11-2014 02:30 PM
got my new coil! xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-21-2010 10:15 AM
coil ? Conquest4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-25-2010 03:36 AM
Coil spring id ric80low 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 02-18-2010 10:27 AM
