Cylinder head freeze plugs - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-15-2012, 10:05 AM Thread Starter
I have a pinhole leak in the cylinder head (400 ci) freeze plug on the rear passenger side of the motor. Has anyone repaired these without removing the head?
I was thinking of getting the old plug out and using a rubber expansion plug to repair it.
Any suggestions?
Thanks Dave Massetti
dmassetti is offline
post #2 of 2 (permalink) Old 01-15-2012, 05:29 PM
If it's where I'm thinking it is, on my car that's where the heater hose "nipple" goes. But... if you can get adequate access to it there's no reason you couldn't change it without pulling the head. Drain the cooling system from the radiator petcock first, but I'd use a brass plug with some sealant to fix it instead of the rubber.
BearGFR is online now
head light plugs Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-01-2011 05:05 PM
Cylinder head question ROBSGTO Engine Discussions 30 04-20-2011 02:59 PM
Cylinder Head Bolts MaL 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 8 09-09-2010 11:10 AM
Cylinder Head Rebuilding Help Needed g-mack 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 03-03-2009 06:29 AM
Can't find set of cylinder head bolts for '04 LS1 GTO westell Service, Maintenance and Technical Discussion 10 05-31-2006 11:53 AM
