Distributor rebuilder recommendation - Pontiac GTO Forum
 1Likes
  • 1 Post By bigD
post #1 of 3 (permalink) Old 11-26-2017, 12:40 PM Thread Starter
I am looking for a reliable re-builder for a recently obtained properly date coded points distributor for my ws code 65 gto tri power. I live in Southern California so LA/SD area preferable but quality is more important.
Johnhw is offline
post #2 of 3 (permalink) Old 11-26-2017, 04:43 PM
Quoted: 54 Post(s)
Not in your area, but a guy who goes by "Sun Tuned", on the PY forum, does dist.
His area code appears to be 901, which is in the Memphis, TN area.
PY Online Forums - View Profile: Sun Tuned
The guy obviously knows what he's doing, as you can tell, if you care to read his posts in this thread he started.
http://forums.maxperformanceinc.com/...d.php?t=811458
1968gto421 likes this.
bigD is offline
post #3 of 3 (permalink) Old 11-27-2017, 10:43 AM
1968gto421's Avatar
Quoted: 70 Post(s)
Sun Tuned has an excellent reputation.
My brother still uses points in his Chevelle but has had a difficult time finding quality replacements for the points locally (China---points burn up, rubbing block wears out.) He got burned on an ebay deal once and refuses to look there for GM points.
With my back problems, I seriously thought about Sun Tuned but couldn't see me bent over checking gap and dwell , etc. On a friend's recommendation, I sent my points distributor to a fellow named Dave Ray who has an excellent reputation for converting GM points distributors to a GM HEI distributor using an external canister coil like the points set-up would. I had mine done and am very happy, still looks like stock points. Like Sun Tuned, Dave will set up a custom advance curve on one of his distributor machines using info you provide him (carb, intake, camshaft, trans, rear axle, etc.). He also provides a list of components he uses and where to find them locally.
Here's a link to a post about him: Who has used Dave's small body HEI's? - Chevelle Tech
Here's a link to his site if you're interested: About - DAVE's small-body HEI's There are several different pages on his site with info. Hope this is helpful.
1968gto421 is offline
Engine Rebuilder in Kansas or Missouri 68SOFGOAT 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 03-18-2015 03:41 AM
Need on-line carb rebuilder recommendation redgoat67 1964-1974 Tempest, Lemans & GTO General Discussion 6 06-12-2014 10:03 PM
Motor Rebuilder jrw63 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 02-28-2014 08:42 AM
Recommendation on a distributor advance kit dastoria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 11-26-2011 09:32 AM
'98 GTO Engine Rebuilder in Dallas? '98 AIV 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-09-2004 12:47 PM
