Dumb Question of the Day - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-29-2016, 08:18 AM Thread Starter
Quoted: 9 Post(s)
I recently purchased a 1966 YS 389 block. I want to eventually purchase a tri-power setup for it. Since it did not originally come with the tri-power setup, I just want to make sure this is feasible before I start collecting parts up.
Thanks for your time!
tiretread is offline
post #2 of 8 (permalink) Old 01-29-2016, 09:10 AM
Red1970GTO's Avatar
All the Pontiac BLOCKS are externally similar (the cast-in engine mounts are different on some models). There are two versions of Pontiac HEADS: those with the run-of-the-mill "D" shape exhaust ports and those high-performance versions with the "O" shaped exhaust ports.
As long as your INTAKE MANIFOLD matches up with your HEADS you're okay. So, YES, there shouldn't be an issue putting a tri-power INTAKE on your engine.
"Honest Honey, it just kinda followed me home, can I keep it?"
Red1970GTO is offline
post #3 of 8 (permalink) Old 01-29-2016, 11:00 AM
The only dumb question is the one not asked.
post #4 of 8 (permalink) Old 01-29-2016, 12:31 PM
Quoted: 98 Post(s)
Tiretread, there is NO difference between a '66 YS block and heads and a '66 WS block or YR tripower block and heads, except for the tripower intake bolted to them. Direct, factory fit, and guaranteed to make the car scream. Go for it! A '66 tripower unit will bolt onto any '65-'81 Pontiac engine except the 301.
post #5 of 8 (permalink) Old 01-30-2016, 07:51 AM Thread Starter
Quoted: 9 Post(s)
Thanks guys! I thought so but i've been accused of being a cut first, measure later, kind of guy and didn't want to go down the road with this build.
post #6 of 8 (permalink) Old 01-31-2016, 06:57 AM
rickm's Avatar
Quoted: 5 Post(s)
the YS block just has the 4bbl. camshaft, that you will replace with an 068 or a different grind.
rickm is offline
post #7 of 8 (permalink) Old 02-04-2016, 07:02 PM
6T5GOAT's Avatar
What about those with the newer style 11 bolt timing cover without the dimple? Anybody running one of those with a tripower?
Johnny
6T5GOAT is offline
post #8 of 8 (permalink) Old 02-06-2016, 01:16 PM
Quoted: 98 Post(s)
You would need to modify the T-stat housing for clearance.
Dumb Question harleynut45 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 05-11-2012 08:38 PM
My [email protected]** ? for the day lol TxSoldier6.0 The Lounge 2 04-10-2011 11:56 PM
Dumb Question ?? Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-25-2010 02:47 PM
Dumb Question? goatcrazy88 2004-2006 GTO General Discussion 7 03-16-2009 10:27 AM
Dumb question AlanSr Interior Discussions 4 02-02-2008 11:46 PM
