Exaust backfiring - Page 7 - Pontiac GTO Forum
 11Likes
post #61 of 64 (permalink) Old 04-13-2019, 06:41 PM
Quoted: 303 Post(s)
Ok, got it. Started a new discussion titled "Distributor Timing" to begin a fresh discussion and separate your situation from the original post.
https://www.gtoforum.com/f170/distri...tuning-134141/
cij911 likes this.
post #62 of 64 (permalink) Old 04-13-2019, 06:55 PM
Lemans guy's Avatar
Quoted: 29 Post(s)
So cj if I had your distributor I would put a breastís bushing in it to limit the travel ad knock that 30 back to 24 or 26.
You would then set the base at 10 or 12 for 26 total. You would then add 10 degrees from a vacumn can for 46 to 48 light throttle cruise.
Once there if no pinging, you cab turn the base up 2 degrees and check if ok you can run 38 total with 22 or 24 degrees idle timing.
You say you must have 26 or more idle timing,...well really you should see it this way a very radical cam CAN take more timing at idle....
But there is not a Mandatory number....24 or 26 at idle is smooth on a hot cam,...20 degrees is smooth on most hot ones.....can you go more?
Maybe but it is a distinction without a difference usually. The total timing is the most important number,....if you want more at idle that you have to take it out of the centrifugal weights,....I have done them 18 centrifugal and 18 base =36....+10 vacumn.......
That is 28 at idle, a real hot cam can take it, but the difference in idle cooling from 24 to 28 is not really of concern. The concern is when guys have base idle at 6 or 8 or 10.......and use ported vac with no more advance at idle.....even at 16 degrees idle timing like you have you will be ok.....you can run it like that....
There is no absolute number, some engines even can take 40 degrees, but you have to be really tuned in, like racers and engine builders like PJ and BigD....they know what their car needs.....b feel and experience..
So donít get hung up on it must be 26 base etc,..the difference of a few degrees will not likely even be noticeable, as long at the total is right nd no knocking
geeteeohguy and cij911 like this.
Lemans guy is offline
post #63 of 64 (permalink) Old 04-13-2019, 07:02 PM
Lemans guy's Avatar
Quoted: 29 Post(s)
Brass bushing ...sorry typo
I missed that notice PJ I was tying the response,maybe it can be moved to the correct forum
cij911 likes this.
post #64 of 64 (permalink) Old 04-13-2019, 09:28 PM
Quoted: 303 Post(s)
OK, got it done. Just did a simple copy/paste to switch it over. Corrected the typo - I won't even ask. LOL
cij911 likes this.
stumbling and backfiring through carb Mr_Roboto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 32 06-07-2013 02:30 PM
Tri- Power Loading up and backfiring timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-13-2013 12:10 PM
Backfiring on acceleration Gtojustin Service, Maintenance and Technical Discussion 6 06-23-2012 07:22 PM
fluid on exaust newtols2 2004-2006 GTO General Discussion 1 02-08-2012 03:32 PM
Backfiring simmons68 1964-1974 Tempest, Lemans & GTO General Discussion 6 08-28-2011 03:39 PM
