exhaust dampner - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-24-2015, 07:32 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
exhaust dampner
The dam exhaust "dampner" on my 67, on the passenger side broke. The dam pin that holds the spring rusted off.
I understand it helps heat up the motor in cold weather, .......
My question is this..............is the flapper open when the weight is straight up and down? It seems like it is.
I wrapped safety wire around it for now.....I just worry the wire will eventually break and the valve close when im out and about. I cant afford a new manifold and don't want to really raise the motor do take the manifold out and remove the flapper.
thanks as always
Tk
Topkat is offline
post #2 of 7 (permalink) Old 05-25-2015, 07:17 AM
rickm's Avatar
Quoted: 5 Post(s)
if you drive it and its closed, its possible to crack the passenger side head from heat.
rickm is offline
post #3 of 7 (permalink) Old 05-25-2015, 07:06 PM
Old Goat 67's Avatar
Weight was there to pull it down when bi-metal spring loosened up with heat, gravity thing you know.
Flapper is open inside when weight is horizontal.
If you have it wired in the up position, you have it closed.
Unless you live in the frigid nawth, it is not needed.
Old Goat 67 is offline
post #4 of 7 (permalink) Old 05-26-2015, 06:02 AM Thread Starter
Topkat's Avatar
Up is closed??
Topkat is offline
post #5 of 7 (permalink) Old 02-03-2016, 11:19 AM
hotcharity95's Avatar
what is it for?
what is it for?
hotcharity95 is offline
post #6 of 7 (permalink) Old 02-03-2016, 06:40 PM
To heat the base of the carb.
post #7 of 7 (permalink) Old 02-03-2016, 08:36 PM
Lemans guy's Avatar
Quoted: 55 Post(s)
We called these things heat riser valves.....as said the spring kept it closed when cold so that exhaust was routed under a passage in the intake underneath the carb....it forced all the exhaust out through that passage under the carb and through the other manifold....once heated it opened and exhaust went out as normal.
They always stuck and broke and rusted and you have to keep 'em lubricated...
Use PB Blaster to free up stuck ones.....anyway I took my manifolds out and used the HO manifolds, no heat riser at all..
If you can't make it move freely from lots of blaster on hinge, the wired open is fine....I don't notice any difference, as long as you have a good working choke system..now in very cold climate sure it may help, but it only stay closed a few minutes...like a choke...
Lemans guy is offline
dampner Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 04-07-2014 09:02 AM
What exhaust?!? 04Black Goat Intake and Exhaust Discussions 0 01-27-2010 03:30 PM
LS-2 GTO exhaust rumble vs. GT Mustang exhaust rumble tiger gto Intake and Exhaust Discussions 10 03-31-2006 06:10 PM
SPINTECH EXHAUST SUCKS, looking for help on exhaust options KERLS04 2004-2006 GTO General Discussion 6 05-31-2005 09:10 AM
