exhaust manifold bolts - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-06-2009, 11:09 PM Thread Starter
On a 1968 gto with the standard 400 engine are there 6 bolts for the exhaust manifold bolts per side.Also do any of the vendors out there have a kit with all the bolts,if not what size bolts does this 400's exhaaust manifold take.thanks.
izzy412 is offline
post #2 of 2 (permalink) Old 05-07-2009, 07:45 AM
67 Basket Case Restorer
Too Many Projects's Avatar
Ames Performance catalog shows a gasket and bolt kit for $27.00 but they want to know what length bolts because of many different combinations.... Not much help if you don't know either. Are you using stock cast manifolds ? If so, measure the bolt hole depth in the head and the thickness of the manifold at each location. The sum of those is an approximate length. You will want a thick flat washer and an anti-turn lock on each bolt too along with the gasket. Those alone may prevent the bolt from bottoming in the head, but I would subtract 1/8-1/4 inch to be certain. Grade 8 bolts from the hardware store should work just fine. Don't overtightened, that's what the anti-turn locks are for.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
Just got my headers...Need advice 05LS2FAST Intake and Exhaust Discussions 16 03-19-2009 07:56 PM
Exhaust Manifold - 4 hours and one bolt out! 70455goat Intake and Exhaust Discussions 7 11-25-2007 08:10 PM
70 GTO 455 Exhaust Manifold leak question 70455goat Engine Discussions 2 11-09-2007 02:31 PM
exhaust manifold gaskets, yes or no. Topgoat 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 09-30-2006 07:38 AM
