Fuel pressure problem - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-05-2016, 11:19 AM Thread Starter
Hi.
I have a 1967 GTO which I own for over 30 years. In 2012 I had the engine rebuilt with a Tin Indian stroker kit. I brought the car to Colorado last year and have been having fuel pressure problems. I have a holly 950 dual feed and I have had problems with vapor lock in the car not running in warm temps. I have 3 pounds of fuel pressure when I start it and it drops to 2 pounds once a gets warm. I believe I should be running is at least 6 pounds of pressure. I have stock fuel lines a high-performance Edelbrock mechanical fuel pump and an in-line fuel filter before the carb.
I have been told I should increase the diameter of the few lines but then I have also been told that that is not the answer. I have been told I should have an electric fuel pump at the tank to push to the mechanical fuel pump.
What do you all feel is the best solution so I can get this fixed so I can enjoy driving my car again?
Sdaly1967 is offline
post #2 of 3 (permalink) Old 09-05-2016, 03:22 PM
Quoted: 6 Post(s)
Did you have the problem before moving to Colorado? Are you in Denver? I wonder if the higher altitude is affecting your pressure. It can certainly make the average mini van from Florida run sluggish. I would try replacing the fuel pump.
Getyourgoat is offline
post #3 of 3 (permalink) Old 09-05-2016, 06:24 PM
Quoted: 361 Post(s)
Could be several things. You will have to do some testing. Assume that you have a fuel pressure gauge located at the carb to know that your pressure is 3 & 2 pounds?
Your fuel line should be 3/8" and should be OK. You don't need 1/2" fuel line unless you are pushing big HP numbers or spinning high RPM's. If you were to go with 1/2" fuel line, then you would most likely need the electric pump at the rear to push the gas to your mechanical fuel pump.
First thing, often times the wrong gas cap has been installed on the car. As I recall, the '67 needs the vented cap IF it does not have the vented tank. The wrong cap can create a vacuum and the fuel pump will starve for gas. So first test is to remove your gas cap and run the engine up to see if this corrects the fuel pressure. If no change, next test.
Next I would disconnect the line that goes from your tank to the fuel pump. Then install a fitting that will allow you to run a long length of rubber hose to a gas can. Fire up the engine and see of the fuel pressure on your gauge comes up. If it does, then the problem is in the fuel system from the tank to the fuel pump. What come to mind next is the "fuel sock" found at the end of the tank pick-up tube has become clogged or collapsed - so the fuel pump is straining to draw gas from the tank.
Check ALL your fuel lines. ALL of them should be replaced with contemporary fuel lines compatible with ethanol laced fuel. Ethanol fuels destroy the older rubber lines. You could have a collapsed rubber line or even a cracked line sucking in air. Check all your lines and replace as needed.
If your fuel pressure does not go up any by doing the gas can test, then the issue is from the fuel pump to the carb. Your fuel pump may simply be bad and needs replacing. Is your fuel filter going in the right position? Some fuel filters are directional specific and if you install them backwards, you won't get the needed flow and some won't flow at all (Silly question, but I gotta ask).
Vapor lock can be a problem with ethanol laced gas when the engine gets hot. You may want to add a gas return line which can help with this problem IF your car does not have one already - it can be added if you don't.
Fuel pressure issue... what to check? r3d05GTO Service, Maintenance and Technical Discussion 0 08-26-2015 02:05 AM
Fuel Pressure Problem? 42867Goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 12-26-2011 05:17 PM
Stock fuel pressure OrbitOrange 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 07-03-2011 12:10 PM
Fuel pressure dropping 69-JUDGE 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 09-20-2010 03:56 PM
fuel pressure regulator? yousaygo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 07-02-2010 05:11 PM
