Grind off lump inside intake manifold runner? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-17-2016, 12:27 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
I have taken the original cast iron intake manifold off my 1974 350 and noticed a small steel "ball" inside the #5 runner, near the exit to the head. I assume that it is a remnant of the original casting process. I had no plans to do any polishing or grinding of the intake manifold runners, but it seems that I should grind this lump out with a dremel. Any thoughts on leaving it alone or removing it?
I have a couple of pics attached.
Thanks.
Name:	intake runner #5 A.JPG
ID:	76466   Click image for larger version
Name:	intake runner #5 B.JPG
Red74Goat is offline
post #2 of 5 (permalink) Old 05-17-2016, 01:02 AM
Thanks.
I would remove it. You will never know how much the slag affects the flow into the heads without putting it on a flow bench.
Probably not much.
My concern would be if that slag would some how break off and end up in that cylinder and possibly bounce around and ending up in more than just that cylinder. I had a carburetor base plate bolt back out and bounce back and forth from cylinder to cylinder years ago.
YMMV
Dave
Hallett Dave is offline
post #3 of 5 (permalink) Old 05-17-2016, 08:10 AM
Agreed, I would remove that before reinstalling.
post #4 of 5 (permalink) Old 05-17-2016, 09:14 AM
I would remove it as well. Maybe just hit it with a screwdriver and a hammer and chip it off.
post #5 of 5 (permalink) Old 05-17-2016, 10:55 PM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
Thanks for the inputs.
I took a very small cold chisel and popped it off with a couple of light taps with a hammer. Came off very clean, no follow-up needed.
Need help figuring out this intake line....pictures inside Berto504 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-08-2014 05:12 PM
Intake manifold orelog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-06-2013 02:38 PM
Intake manifold Legend 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-16-2012 11:33 PM
1971 Road Runner Falco21 The Lounge 30 05-19-2010 05:59 PM
