Head Bolt Recommendations - Pontiac GTO Forum
post #1 of 6 (permalink) Old 06-22-2016, 10:01 PM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
I pulled the heads off my 1974 350 due to two broken exhaust manifold bolts, which I needed to have removed by a machinist.
When I pulled the heads off, the threads on two of the head bolts got damage and will not cleanly install back in. Any suggestions on where to get individual head bolts? Seems it is relatively easy to find head bolts sold by the set. Would a new full set of ARP head bolts be the best way to go? The engine only has 28,000 miles on it and the heads have never been pulled off before.
Thanks.
Red74Goat is offline
post #2 of 6 (permalink) Old 06-23-2016, 08:18 AM
No reason for a set of ARPs, just source the correct length nice used head bolts. Which position bolt do you need?
On a '74 Dport engine, the longest bolts (and two studded bolts) will be right under 3 3/4" measured under the head to the ends of the threads. The long front bolt on drivers side exhaust will have a threaded stud to attach neg battery cable. Same studded bolt was used above center exhaust port on pass side of block.
post #3 of 6 (permalink) Old 06-23-2016, 11:56 AM
Quoted: 98 Post(s)
X2. Also, some ARP head bolts are a hair too long, which causes them to bottom out before the head can seal up with the block enough, causing head gasket failure.
post #4 of 6 (permalink) Old 06-23-2016, 01:02 PM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
Pinion,
It was the two lower, front bolts (#1 and 2 cylinders), the bolts NOT under the valve covers. 4" long, including the hex head, 3 3/4" under the head, shaft and threads only.
Thanks.
Name:	GTO 350 Head Bolt.JPG
post #5 of 6 (permalink) Old 06-25-2016, 09:17 AM
Depending on how they're damaged, you could also purchase the correct size die (as in tap and die set) and attempt to clean up the threads on the bolts you have. Just make sure that the bolt threads haven't been rounded/smoothed off to the point where they won't be fully gripping the threads in the block.
post #6 of 6 (permalink) Old 06-25-2016, 01:43 PM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
Thanks for the suggestion Bear.
1964 12 bolt to 10 bolt remy30006 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 08-06-2013 10:53 PM
Speaking of headers-head bolt hole question russosborne 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 02-09-2011 08:35 PM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 03:30 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 03:45 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 04:34 PM
